The Ultegra is better suited as a surf castng reel .
The 10 000 will be good enough , but if you buy the 14 000 , you will also get the 10 000 spool as an extra.
The 14 000 spool takes exactely 600m of 50lbs 8 STRAND HMP braid - nice for windy conditions.( even sharks )
The 10 000 spool can then be loaded with normal .42 high abrasion line for fishing on the rocks.
The sustain will be better suited on a 12 ft rod - we use both the Stradic , Ultegra and Bulls eye reels and they have performed well under all conditions.
The Ultegra can also be improved with some carbontex washers which you van purchase from Enigma ( on Sealine )
