shauncooper
Hi all - I currently have a Lowrance HDS7 Gen 3 with Airmar transom mount transducer (with Chirp) as well as LSS2 Structure Mount Transducer -
I want to add an in-hull transducer to my Buttcat so that I can still read bottom while under way as I'm trying to pick up new reef.
Is there anyway I can have the Airmar plus another Transducer or will I have to keep plugging one or the other in? If the only solution is to scrap the Airmar transom mount (virtually brand new), what in-hull would be recommended that can do the same/similar job to the Airmar?
