Multiple Transducers
shauncooper
Hi all - I currently have a Lowrance HDS7 Gen 3 with Airmar transom mount transducer (with Chirp) as well as LSS2 Structure Mount Transducer -
I want to add an in-hull transducer to my Buttcat so that I can still read bottom while under way as I'm trying to pick up new reef.
Is there anyway I can have the Airmar plus another Transducer or will I have to keep plugging one or the other in? If the only solution is to scrap the Airmar transom mount (virtually brand new), what in-hull would be recommended that can do the same/similar job to the Airmar?
Craig.fish
As long as they run different frequencies, youll be fine. I run a Lowrance Chirp 83/200 skimmer as well as an Airmar P66 running at 50 and they dont interfere with one another at all.
shauncooper
Thanks Craig - its not necessarily the frequencies I'm worried about but how to physically connect more than one transducer to my HDS7 unit.
Are you using a sonarhub to do this?
Craig.fish
Ahhh....i see.
Im running 2 seperate units. A HDS as well as a Hook7.
Speak to John Easton on 082 558 2719. Hes the Guru and will sort you out.
