Mould making
Mangi
Great post Bennie! Mana to you!
Without hijacking your thread, do you know how to make a mould for grapnel sinkers?
Howzit mangi,
Thanks boet, don't stress..., that is what this thread is about.
I havn't made a grapnel sinker mould but I recon you could use the sinker as per the instructions. Then just drill the holes through the mould where you want the wires to go through. One wire would go beween the 2 halves of the mould and one at 90 gregrees through both halves. An idea, instead of removing the wires, cut them short. This will leave an impression of the wires so you know where to drill.
Bennie
Thanks for the awesome comments guys.
I made this mould with as little effort as possible so that I can keep it simple enough for anyone to do. If you really wanted you could make the first half as per the whole procedure, then place it on a flat belt sander to make the face flat. Then do the second half which will make the 2 faces true and give you a split right in the middle of the casting. This is the best bet if you are making a grapnel sinker mould. I will be making another sinker mould, a standard 12 Oz sinker. I will post the additional steps.
B
naks
thanks BENNIE really appreciate your willingness to share your knowledge and know how.GOD BLESS
tauruck
Homie wrote:
Mickey,
Where is springfield in gp ?? Is this near you in Buccleuch ?
Springfield is in the south of Joburg opposite Wemmer Pan. Down Eloff str Ext past the Cement factory and just before the Rand stadium on the left.
nicos
So I call Bennie this morning to ask him how he makes his moulds... and his answer is simple: use SEALINE!
What an excellent post, will be making some spoons soon and will let y'all know how it goes.
BTW, where does one by plaster of paris? The chemist?
Thanks!
Your local hardware should stock it.
Patrick
I found the best PoP from either Clicks or any other chemist. The stuff they sell at the hardware shops down here isnt the same. I find it doesnt dry white and is weaker.
AndriesH
Mica, Builders W/house, Timber city All between R9.50 & R 11.50 per 500g.
You just got to find it yourself as 4 out of 5 assistants couldn't assist.
Check at the paint, then the colouring powders (oxides) and then at the fillers (polyfilla etc)
abloke
Excellent stuff!!..very informative.I'd like to make a mould of a large star sinker (for surf sharking) that my late friend made and will be able to use this info.
