Motors
CLS
Hi all. I am a weekend skiboat angler and would like some advice. Last week I had trouble starting my motors, they would start and stop, start and stop until they idled a short while then cut out then would idle longer and longer until running smoothly.I had not launched for 6 weeks due to other commitments, I have not had this problem if launching each week, and the motors were recently serviced, they are 2 year old 60 - 3 cylinder Yamahas. My question is should one run the motors dry or not ??
Propwash
I try to run my motors at least every 2 weeks if I don't go fish. You find that the fuel evaporates and leaves the 2stoke oil behind that forms a slurry in the carbs, hence the hard starting. If you are going to leave the motors standing for more that 3 weeks rather run the carbs dry.
MOGGY
Never run your motors dry, especially two stroke pre mix motors.
Your crank is dependant on the oil, in your fuel, for lubrication and if you run the motor dry, you are starving your motor of fuel and lubrication.
When you travel, make sure that your float bowl has fuel in it, because the liquid acts as a damper.  If you have no fuel in the bowl, then the float bounces up and down, repeatadly ramming the needle into the seat.
The modern two stroke oils mix very well with the fuel and you should not have any adverse effects.
For longer storage periods, you can drain the carbs, by using the drain screws.
bernssurf
Very interesting, I was under the impression you must always run the motors dry. Thank you for the advice!::jdski
Dorado75
me too, thanks for the info!
My mechanic told me that a 4 stroke should not be run dry either!
