Looking for a combo 10 or 12 ft rod cast weight sh
robyosh
Looking for a combo 10 or 12 ft rod cast weight should be around 4 oz and looking for a coffee grinder to go with it.
Used for R&S scratching
or even ideas
nevillebarnard
i use two setups. the first is a 10.6f Waft Venom Drop shot rod tated as heavy. it can do up to 150g. I use the Venom real with it loaded with 20lb Vortex Casting braid. It would discribe this as a med setup.
Then i also use the Waft Iron Feather Spinning Rod in the 11.6f. This rod is very powerfull and can cast up top 6oz. i Use my Ultigra Ci4 14 000 with it for casting 3 and 4oz poppers for Garricks. it also works very well for scratching. This is the two i would look at.
KARLR
Rob,
I have a Kingfisher HMG36T - 10,6" 3 piece combined with Shimano Spheros 5000Fb grinder.
Very lekker rod, mainly used for spinning, plugging.
You're welcome to make a gooi with it.
robyosh
That would be great, really appreciate it.
Went to all the tackle shops looked at the dominator and the terminator both very nice but don`t like the cork grip on the dominator.
Was also looking at the exage 4000 reel to pair with it - what you think about the combo ?
KARLR wrote:
Rob,
BTTB
Looking at your profile Robyosh, what is wrong with that 10ft Exage listed under your equipment, that rod is a legend and will cast 4 ounce with ease.
robyosh
It`s made for a multiplyer.
I`m really enjoying it and have had so many fish to thank for it but I would like a coffee grinder as to fish with the 100m + sl30 with braid on is fun. I just want some thing else
BTTB
I see you live in the Wilderness. There is a tackle shop in George on the Main Road closer to the Airport side that is selling a 10ft Exage as a Combo. The Exage comes with a Shimano Aceration 6000, selling for R2800 I have been told.
sandgrain
Hi Neville, what type of leader did you use on the Venom rod and real and is it necessary to put some mono under the 20lbs braid for backing, apparently the braid can slip on the spool with no backing.
Popper9
Wel hier is my scratching gear...
Ek het n dominator gehad wat ek n Penn fierce 8000 op gehad het hy vol 20lb sufix 832.Gooi 2oz n myl met hom.Kan 3oz ook gooi maar dan begin dit vir my die doel weg vat van "scratch tussen die rotse".As jy scratch wil jy nie doer agter in die blou water gooi nie.Jy wil hier voor ini gaatjies gooi of n akurate gooitjie maak tussen twee klippe.
Ek het dan ook n kombinasie van n 12ft loomis 3 stuk met n finnor 16ofc wat 30lb sfix 832 op het.Met hom gooi ek 3oz en soms n 4oz lood.Veral as die water bietjie te sterk is.
As ons veral galjoen gaan vang vat ek net daardie 2 stokke en 9 uit die 10 keer gebruik ek nie eers die loomis stok nie.
Daar is niks lekkeder as die galjoene vreet om hulle op die 10ft te vang nie en so tussen in tel jy n kraker op, dan is dit nou eers sports.
Baie gelukkig met my outfit vir die winter...
::S
Splasher
Huh, what about Poseidon HMG 11'6" ultralight spinning 1--3oz.................? Plenty of grunt in this rod to tackle what ever is between the bricks!
