Load the gun
skrops
Ringo,
buy something that has been tried and tested, daiwa exceller comes out tops in the price range. Also look at aftersales service, daiwa you will always be able to get spares. too often I have heard from guys that they can't get spares.
Ringo
Hey Skrops
I hear what you saying.Im thinking of going with the daiwa excceler , Fire line crystal.and now i want to know what line to use for leader.fireline vanish is that any good?
dugongboy
Check out the smaller Okuma Salinas - great value, well built (full metal jacket), fantastic drag(dual) - It is a bit heavy but much stronger and will (should) outlast the Excellor.
I have a Salina 55 spooled with 20lb braid which is used for spinning and offshore dropshotting and jigging and it is awesome - you can even crank up the drag a fair bit - I must admit it has only been tested on a few 3kg Kawas a big (about 6kg) Skipjack tuna and a 4kg YFT.(all of which gave the drag a nice little 'running in' test) but our FADS are in place and it will only be a matter of time until it is tested on a decent bull dorado !!! - I will keep you posted.....
Dorado75
Hey Guys, i have just bought my first dropshot Rig, bought the Shimano Trevala Rod and the Penn Applause 4000 and 20lb Suffix Braid, mainly wanna target Kob with the set up from my ski!
I would have liked to go a bit lighter but the place that i fish is right inside the kelp!
I would love to try this rod out in Angola Offshore, i can not believe the power of this rod!
Ziyz
[color="#006600"]Reefman[/color] wrote:
As Dingle said... 8-12lb Fireline is going to be just fine.... I have 270m of 12lb Fireline on my Exceler 4000.
:pReefman, what droshot (and other) rod do u match with your Exceler 4000?
I want to get either the Exceller 3000 Plus or the 4000, but am at a loss as to which rod to match these with. I'll mostly fish durban bay, inshore and estuaries - in that order. Any advice would be greatly appreciated.:sos:
Sorry for the hijack Ringo.::tight:
esatpil
Hey Dorado75,
That trevala rod is awsome man,saw one in December but it was only 1 piece and for me to travel with is an issue but damn I was hoping it comes in 2 piece.
From what I have seen on the Shimano website they built it for those Butterfly Jigs so it must have some seriaaas power.
Dorado75
Yeah, the one piece thing also put me a little off but i can get around that..... i have not checked out the butterfly jigs but this rod does have serious power...... it is rated 20-50lb, which is incredible for such a small rod! Cant wait to hit the water for a few Cob next week!
I use the 7ft Shimano Beastmaster medium heavy rod with my 4000. It's a bit heavy for that setup, a 2500 or 3000 would be better. But my 4000 doubles up as a spinning reel - it comes with 2 spools - with the other spool I use it on a Shimano Exage 10 ft rod and use it to spin with spoons and plugs.
Ziyz
Got the Sensation Power Plus today.
Lovely rod. Hope it can handle the 4000. If not, 3000 it is!!
GL
[color=#006600]esatpil[/color] wrote:
Hey Dorado75,
Shimano launched a new range in Jan 2008 that comes in 2 pieces called Jigwrex, option available for multiplier or grinder, perfect for travel. Have one rated for 300g but comfortably jigged with 150g - 425g jigs. This range is awesome.
Also have Trevalla medium jig rod and its great with Trini 16 but little soft for jigs >150g and big fish as it bends too much and you battle to put pressure on fish.
Ringo
Hey thanks for all the help.I finally got the Penn Applause and it's great.With fireline Crystal 10lb. And a diawa  megaforce 7 ft rod.
Got my first garrick yesterday and going again today.
Thanks again
Dorado75
Hey Ringo
Which Applause did you get, i have the 4000, got 20lb braid, really nice reel, hope to put it properly to the test on Sat with a few Kob!
Ziyz
The Okuma Salina and VSystem seem to be pretty impressive reels. Good bang for your buck and AMAZING drag pressures.
Chech out this link:
http://www.okumafishingforums.com/showthread.php?t=445
They're in the same price bracket as the Exceler and, from what I've heard, are pretty durable.
Anyone have any idea how they would stack up against the Daiwa Exceler Plus?
