Live bait setup
eXtincT
lol. try saving it to your desktop and opening the file. If it doesnt help pm me and ill resize it for the forum...
eXtincT
ok. ill make this a little easier... You can see the pictures fine. SO...
Towing bridles for live bait trolling is a good ideal. We use the double0loop bridle pretied in monofilament because it allows the bait to be attached and placed back in the water in the shortest possible time. To make a double-loop bridle we need a rigged leader with a suitable hook attached, a lingth of 24kg monofilament or thereabouts, an open-eye live-baiting needle and a loop gauge which can be a pencil or pen.
1a The bridle itself is simply a short length of monofilament with a sliding noose in each end.
1b We begin by tying a noose on the hook and pulling it up tight using the knot configutation shown here known as the Centauri knot.
2a Then we tie another sliding noose in the other end of the monofilament, keeping in mind the bridle needs to be quite short, say 100mm for towing striped tuna and about 75mm for slimy mackerel. Tying bridles of this short length does take a little patience.
2b. Close the loop up on you loop gauge or pen, but not so tight that you cant get it off.
3. Slide the loop off your loop gauge and engage your open-eye live baiting needle.
4. When the baitfish comes aboard, the hook is usually cut straight off to save time and the needle is passed straight through the eye tunnel of the baitfish taking care not to damage the eyes.
5. Pull the second loop right through and hook it over the point of the hook. Then disengage the loop from the open-eye needle.
6. The bait is placed back in the water and trolled slowly, usually as slow as the boat and go - and if possible - back towards the shoal of fish from which the bait was caught.
Note thee is a little slack in the bridle. This allows the hook to fold bait easily when it is taken by the game fish. Anglers who rig the hook too tightly on the head miss fish because of this...
Hope this helps a little.
