Live bait setup
Durran
Hi guys,
There has been a lot of talk about using circle hooks and getting better hook exposure to ensure better hooks ups (either J or circle hooks).
I know when the deep sea guys troll live bonnies they bridle them (i think this si what its called)
IE: they use dental floss to secure the bait to the hook. Has anyone tried this with a lvie shad for example? Should give the fish better movement and ensure the hook is set better with less chance of the hook folding over.
Thread the dental floss through the shads nose/eyes and then bridle the circle/J hook to that on a standard live bait trace???
misguide
Durran,
This is something I have seen the boat guys do but never thought of trying for R&Surf.
I reckon it could work....just a little off putting about the hooks being out of the bait.
I reckon I will give it a try when in the Kei again.
nicos
I recently started seeing ppl do this with dead baits and circle hooks. Think it was also on one of the ESA shows?
Haven't tried it myself with R&S, but definitely going to give it a bash!
OFC
it is also in this month's issue of the ESA mag! looks interesting!!
sorry! bad pic, took it with cell out of mag!
Homie
Dont think it would work for a live bait, threading the dental floss should surely kill it ???
misguide
I am sure you can go through the eye sockets as well if the nostrils are a problem...the deep sea guys should be able to help here?
Tuna you done this thing with live bait or dead bait?
OFC
maybe not if it is only in one of the jaws?  might even give the bait more freedom to move and panic!!:ssswim:
Johan Fourie
There is a cavity the run infront of a fish's eye's - side to side - if you put the bait needle through there, and pulle the dental floss through - it does not kill the live bait - do it all the time with bonnies on the ski boat - so it could work on shad etc - I just think you would have difficulty with small bait such as mozzies or small macks
Homie
Just playing Devil's Advocate here, but say we can thread it without killing the shad, Whats to stop the shad from biting the hook, and hooking himself, or biting through the dental floss ??
We would have to thread it through the top jaw only, thus allowing the fish to breathe
nicos
When bridling live baits on the boat I like to have the hook tight against the head, no way the can bite it!
I've also recently started using cable ties to bridle, works really well and very easy to do! Will find a pic.
misguide
Homie, if the dentail floss is a problem then use a piece of 50lb Dacron or similar braid...no ways he gonna bite that off!
Homie
Ok ! That sounds better. So not like the pic OFC posted.
@ Misguide,
Been thinking (not good for me, I know) about this,
Surely the fish would try to bite it, no matter what you used, as it would probably want to get away (me thinking like a fish)
This would be good, and bad (so I think, told you its not good for me)
Good - It will imitate an injured fish, and attract the big nunus ( ok, not imitata, it IS an injured fish)
Bad - can get burnt off, break free, get stuck on structure ???
nicos
OK, couldn't find a pic on the net, and my tools here consists of MS Paint only, so excuse the beautiful artwork (I do think the fish looks deep in thought).
Cut the cable tie into a sharp point as shown, push through the cavity in front of the eyes, zip up and insert hook under cable tie. Quick 'n easy.
Katonkel Tom
Nicos the hook is so close to the head, why not just hook the hook straight inn? It should do less damage than a cable-tie being alot thinner?
nicos
First, let me say that I didn't come up with this rigging :)
With R and S, I usually put the hook throught the top jaw, the fish can breath freely and lasts a while.
When trawling a live bait, there is quite a bit of strain on the fish and the hook will make a hole that gets bigger over time. I guess that when it gets hit, chances are it will pop off the hook.
With heavier baits (like bonnies), there is a chance that the weight off the bait could actually pull the hook out after setting. Some people ose rubber bands which will snap.
In the end, there are hundreds of permutations, and like everyne else I am still experimenting, and couldn't tell you what works best! One thing I do know, when you use a circle hook it needs to be as proud as possible, and for that some of these methods are better.
Durran
Nice input guys, sure someone will try this this Garrick season and by the end of winter should have a good formula
