I wanted 2 knw wat knot would be suitable to tie 1mm minimum leader without my rings taking a beating but still have full knot strength.By the way my mainline is 0.55mm.:fst:
I have tried the bimini twist but can't seem 2 get it so I used the spider hitch.Also is the double figure of 8 knot supposed to meet up with the spider hitch knot if not what could be a suitable distance between them(i'm now using 1mm)
Very true, I even loaded the vids onto my cell so I could refresh the memory, if ever I get broken off and have to rerig on the beach. thanks ReefmanFossilz wrote:I have tried the bimini twist but can't seem 2 get it so I used the spider hitch.Also is the double figure of 8 knot supposed to meet up with the spider hitch knot if not what could be a suitable distance between them(i'm now using 1mm)
man...you must deffinately check out Reefmans video of the Bimini!!!
i could never tie that bugger, untill i saw that vid.
thanx again reefman!!!![]()
