Leader
Fossilz
I wanted 2 knw wat knot would be suitable to tie 1mm minimum leader without my rings taking a beating but still have full knot strength.By the way my mainline is 0.55mm.:fst:
Rings??? Do you mean guides (rod eyes)? All the knots you need are in the faq Knots section....
http://www.sealine.co.za/view_forum.php?id=44
Bimini twist mainline with double fig 8 (for leaders up to 1mm) is the way to go. Above 1mm, then Wind-on leaders are the better option.
Fossilz
I have tried the bimini twist but can't seem 2 get it so I used the spider hitch.Also is the double figure of 8 knot supposed to meet up with the spider hitch knot if not what could be a suitable distance between them(i'm now using 1mm)
RICCI
man...you must deffinately check out Reefmans video of the Bimini!!!
i could never tie that bugger, untill i saw that vid.
thanx again reefman!!!::S
camo shorts
Very true, I even loaded the vids onto my cell so I could refresh the memory, if ever I get broken off and have to rerig on the beach. thanks Reefman
