lANGEBAAN LIGHT TACKLE MISSION
Joker
Lekker vis daar Stinkmossel.
Dit lyk asof julle n goeie dag/dae gehad het.
Daardie ligte gerei setup; as ek mag vra. Wat is dit?
stinkmossel
ek gebruik n daiwa exceller 8ft en shimano slade 4000,met 10pond braid. Die hoeke is 1/0 circle streamers. DJP,ek dink ek sal n 5kg smoothie kan handle...
stinkmossel
koper, ek ryg d wurm so 5cm deur en maak n draai met d hoek trace om d wurm, om te keer dat hy afgly.dan reg ek d res deur,en maak seker dat d hoek goed uitsteek.
lushwill
howzit, well done on the catches
what size sinker do you use? and do you use a running trace with a ball sinker? dankbaar
Wayne
Nice fish boet,is this the old Spreeuvalle entrance or the new one that you need the permit to get in?
neilg
DJP wrote:
So kolhol baklei darem lekker op die ligte gerei! Die baan Smoothounds vrek mos ook vir 'n bloedwurm; dink jy, jy sal een kan land op daai 10lb outfit?
A few months back a 80-100kg Raggie was landed in Blue Water Bay, tackle, 2500 reel, 10lb mono, 6.6ft spin rod and bucktail jig
Have to add it was on the surf
Nice catches guys, I need to go fish again
Pslatarix
hunting elephant with a .22 that is! Lmao. How long did it take the guy to land?
Daisy
Wayne the gate at the caravan is open,With the road construction,they have put a guard there that will open the gate...but he goes to the shop often...LOL
