L&F Sharkey leader thikness
TimJan
Hi guys
I bought a L&F sharkey that i want to use in the sardine run my question is what is the max thikness leader i can use? I have a couple of 1.5 and 1.6 and was wondering if these are ok for the rod eyes?
Mango
TimJan if you are using a knot to connect to mainline I would recon 1.4MM but then you will need very neat knots .
Why not change to wind on leaders then you can cast up to 2mm no problem
TimJan
Sorry i am using windon leaders with a bimini on the mainline and a catspaw. Thanks for answering my question
Mango
As Arno said no problem with those thicknes leaders I have casted up to 1.6 mm with wind on leader just keep your cats paw neat and the loops used for the cats paw short.
Enjoy
Arno Nel
I have used 1.8mm on my 16mm guides with now problems.
T-Line tapered leaders are also great but since I started useing my won Wind Ons I would not turn back. And you have less knots to worry about.
Arno Nel
The advantage of the wind on leaders is that you eliminate the knot between the loop and the leader which makes a big difference when going to large diameter leaders.
