Knot
Saxon
[suP]Hi All[/suP]
[suP]Have bought a braid called Double X Viper it is ultra thin, am having a problem knotting it to the spool. Any help?[/suP]
Hooked
Read up on Reefmans previous posts under the knot section .
Alternativly wait until he replys on this thread.
LOL @Hooked!
In the FAQ section on KNOTS - there is an ARBOR KNOT. Tie this knot onto the spool, then use the Sticker or some sellotape to stick the first turn down and stop it from slipping.
Saxon
You could also tie some fluro or mono line and spool that onto the reel first, and wind it to a couple of turns, say ten or so, that will keep the braid from slipping on the naked spool as it would if it was done with the braid directly onto the spool.
for the knots, do read the Reefer's tips, it's realy worth it.
:f1shy
Orange Elephant
morning all.
I am battling to tie my leader (.65) to my main line without it breaking at the knot. The main line is .24. I dont want to use a swivel because I feel it doesnt let you present nutuarly. Any ides out there?
[color=#006600]Orange Elephant[/color] wrote:
morning all.
Bud, read up on the REEFER's knots, try the double Uni knot, specially when you're line differ so much in diameter and still keeping most of your line strength.
:f1shy
Nepptune
Albright or GT knot would be your best bet with two different thicknesses of line.... I'd suggest creating a double line in your braid with a bimini twist too....
All knots shown in the KNOTS thread...
Neps, Eish man I can't do that bemini twisting thingy, perhaps one day I should stay at home and try it, till i get it right, or pay the Reefer sum serious money to teach me.......
Hope he doesn't read this, caused then my wallet is going to look like it's been on some self inflicked starvation crusade...... for years already.
:f1shy
Saxon
Thanx all, have found a very nice glue at our local flyfishing shop, called Knot sence, it stays liquide untill you expose it to uv light (sun light ) then it sets, but has elastic properties. Tested it in a vice, the braid snapped and the knot stayed good!
Nepptune
LGF - Boet, its not that hard, seriously... bu7t much easier if someone shows you....
You don't have to have one, but once you learn it, its pretty easy ... don't be a knot-o-phobe bru, get in there and do it!
Nepps, thnx Bru, will try it, only thing is that I haven't yet tried cause the Double uni seems to be quicker, easier and keeps up to 90% of line strength so, for the added 10% it just hardly seemed worth the hassle to try to perfect the Bemini twists. But One is never too old to learn.
:f1shy
Saxon
Ok its called
UV KNOT SENSE
Tube, made by Loon Outdoors
Web: www.loonoutdoors.com
Paid R145, but you only use a very small amount.
Saxon
Land Locked
Gents, the bimini is DEAD EASY. If you had been at the social on the weekend past in JHB you would have been able to learn from reefer the knot master himself.
Strepie
Like Uncle Mickey said, try tying the BT late at night when the fish is biting or the wind is howling. A totally different story.Just my 2c.
lerouxjaco
:f1shy
Hi LGF
Dunno if this will help with the bemini twist, but the easiest way for me is to fold the line double wind your 21 or whatever you prefer like Reefman said 12 for braid, open the loop and put both your feet inside your loop put the top of the Bemini twist where your twist are over your knees pull the twist lightly down to your knees and hold the line and the other loose end tight at 45 degrees upwards. Open your knees to put tension on the twists at this point you will being “loading” the twist, before closing your knees again take the loose end line and angle it at 45 degrees downwards, while closing your knees the loose end line will neatly slide downwards on the twist 2/3 downwards angle the loose end at 90 degrees and wind it on till at the end of the twist tie the loose line to the one end of the loop then the other and then twice on both the loop lines together. The most important part is to use knees to control the winding of the twist just close your knees slowly to give you control of the winding of the line onto the twist. Once you have mastered that the bemini is very easy and quick to make.
This method only works if you don’t worry about a long double line as I usually trim my double to the length I want to use.
Hope this will help a bit   ::tight:
