Would you be so kind to explain this dipping/calling a fish? I heard ryan mention it before... Do you just dip the loodkoppie in the water from the boat and wait... will they come to investigate? Any info will help.
Well it comes down to ploncing the leadhead repeatedly and then let it stay still for a while, ploncing again and then stirring the water softly with your rod tip.
But beware, if you do it with a normal rod chances are you'll wrap the line around your tip eye and your tip WILL brake on the take.
That is why we use the trough line rods "Calling Rod / Roepstok"
Your loodkop hangs about 50cm in the water, it can be done in the open or in structure like watergrass or snotrebella or so, there is plenty info about these rods in the barbel forum, you wont walk into a shop and buy them, special orders only
middag, hoe ver onder die stok se punt laat jy die kunsaas hang40 tot 60cm? jy kan seker visaas ook gebruikom mee te plons, karpkoppie of n padda?
stinkmossel
Jy kan aas ook gebruik, maar die goed val af as jy daarmee klop. Jou resultate is ook nie noodwendig beter nie, want dit is 'n reaction strike wat jy kry.Gewoonlik hang jou kunsaas net buite sigafstand.
