EVER REELED IN AFTER A CAST AND SEEN YOUR BAIT PULLED UP OVER YOUR HOOK OR PERHAPS UP YOUR LINE?
GIVE THIS A TRY, ESPECIALLY IF YOU CLIP YOUR HOOK TO THE SINKER FOR A LONGER CAST. THIS LITTLE BEAD CUT IN HALF WILL PREVENT THE BAIT FROM MOVING UP OR DOWN. IT WORKS......TRUST ME.
FOR A CLIP THROW, PUT THE BEAD ON THE HOOK WITH THE FLAT EDGE FACING THE BEND AND FOR A STANDARD (UNCLIPPED THROW) PUT THE BEAD ON THE LINE WITH THE FLAT EDGE FACING UP THE LINE.
I GUARENTEE YOU WILL IMPROVE YOUR HOOK SETTING RATIO.
