I have just posted a new question but not sure if
Grant Thorpe
I have just posted a new question but not sure if it actually went,here it goes again:
Good day to all.
I have orderd a 28' Buttcat from John Butt.Would you know who I could ask to build a good surf launching trailer for it.I would like Oil filled LA Axles with a hydraulic breaking sysytem.I need a good quality trailer.
Have a look at the 28' Butt that is for sale on the supremecraft web site,it's a brown and orange one,I am really like the deck layout,would you know who could make these types of seats for me?
tkei
Grant,
Good one on the order. What is the lead time???? Hopefully he quicker than he was on mine, but he did say he focuses more on the bigger baots.
As for the seats, are they not std Butt cat seats?? I have seen them on a few, so may be standard.
As for a trailer, A&G (Supremecraft) are meaking trailers for john i believe. Not sure what they look liek or how they work. Lee cat are also dowen that way and they make solid trailers for their boats. maybe contact them. May be able to help you out.
I look forward to seeing he end product in a few months time. How many ponies you putting ont he back?? Make??
Did you come right with the old boat and the motor problem???
miles
Hiya
That boat has the full sportsfisher cabin.
Also have a look at his walk-around cabins. They are a tad bit smaller than the full sportsfisher cabin, but does offer ALOT more fishing space.......
Grant Thorpe
I have contacted A&G and I am awaiting a quote.I spoke to John and he said that I have to much weight in the front of the boat.My fuel,batteries etc. are adding to the problem.He said I must at least get my fuel to the back middel of the boat.
Grant Thorpe
I have ordered the walk around plus I have made the cabin a bit shorter as we don't get the bad weather the Cape gets and I feel it might get a bit hot inside.
tkei
John is very anti the fuel upfront. we put ours there and no problem, but we do put all crew at the back otgherwise she is very wet.
also our batteries are at the back. try that and see if it helps. be interesting to see. I recall someone having similar problem with a v-cat a while ago. be interesting to see if that helped him.
miles
Hiya
Been on / owned / fished off:
18' Butt-cat
21' Butt-cat
23' Butt-cat
26' Butt-cat
28' Butt-cat
30' Butt-cat
33' Butt-cat
Have been on the 36' Butt-cat on the marina, but haven't been out to sea with it.
What info. are you interested in?
Regards
miles
MCD
Hi Miles
I have been told that there is a new Butt Cat that is 200mm longer than a 28ft but 400mm wider, they call it the 8.65m. So it sounds like it is not a 30ft, but is bigger than the 28ft, maybe 29ft. I have not seen one but heard it looks very good, as I am looking to buy a 28ft this looks very good but can't find someone that has actually been on one. Any info would be welcome.
miles
Hiya
I've not heard anything about this new butt-cat, best bet would be to contact John Butt directly.
It how-ever doesn't sound feasible though. Look at the standard spec's:
28' Butt-Cat
Length : 8.50m
Width: 3.0m
30' Butt-Cat
Length : 8.95m
Width: 3.3m
As you can see, the boat you're most likely referring to would be a 30' butt-cat, just shortened. I could be wrong though!! Just seems a bit silly to make the 28'er wider, about the same width as the 30'er, BUT shorter. Either way, when you make the 28'er wider, its will not be legally towable on the roads, so you might as well look at the 30'er then.
Hope that was of some assistance!!
Please keep us updated at to what you find out!!
Regards
miles
Grant Thorpe
Hi there Miles
The new 28' has a length of 8.65m a beam of 3.1m where as the old one is 8.4m long and hasa beam of 2.9m,whether you can tow the new size boat is questionable as stated.
miles
Hiya
Do you know whether the actual HULL is the same 28' hull and just the top deck that has been extended, to make it a bit longer and wider?
Or is it a complete new re-designed hull as well?
MCD
Hi
On the price list from Buttcat they have the following sizes, 8.4, 8.65, 8.95. The local guys recommend that I look at the 8.65, quite a few guys are planning to upgrade to this size from their existing 28ft boats. There is one being built for a commercial boat here in St Francis which will be the first one in that size for up here, meaning I haven't seen one just heard of it.
gut
Hi Grant
Contact Jan Wesselo he is a registered trailer builder who operates from Bathurst just outside Port Alfred, if im not mistaken he builds trailers for some of the local boat builders u can possibly save by contacting him direct. His home no. 046 6245099
gut
Murphy
Where can one have a look at the Buttcat range???
Either I'm blind or just not looking properly, but can't find reference to the various Buttcat's available - other that Sealine.....
tkei
No Butt cat website, best bet is to find out who has them in one area and contact he owners and have a look around.
tkei
I evntually found a few pics of my butt cat . Not the best pics but you can see the general layout and the new items John built for us, ie new narrower console, false transom and live well etc. T-Top still to go on before dec.
