Howzit,maybe strip the reel,lubricate the bearings with rocketfuel and try casting again.Also check if all the brake colars are in place,if they are in,in the first place.A missing brake colar can put the spool of balance.Better you open the reel and check if anythings wrong,because if anything is,you can return it.
Right on the money!slms
take off the line and use a plier to pull of the pin thats on the spool.
this reel was designed for boat fishing and that pin is used to attach the line onto. not meant for long casting
throws briallintly and the vibration will disappear after u pool the pin out.
if u dont know how to do it....rather let sum1 who knows....just incase u scratch or damage the spool.
habib wrote:Right on the money!slms
Nice Buy Saltiga ou !!!
Great reel .
take it back !!!
last question are u gonna change yr name to Torium ou ???? LOL ...
Shimano Ou.......sounds better!slms
Eish, the stuff you have to do to a Shimano, just to be able to use it !!!
