Howzit guys,i have a Saltist 50 just laying around
neilg
After the test they advised that it is Seriously Highly International Trash
Read it again and again, till you see what I'm saying !
Walt
pieterh wrote:
Ja Julle sien. :D
DAIWE IS TOPS.  :first
Hi Pieter!Gebruik jy nog steeds Diesel in die Daiwa?Ek wou jou lankal vra of daai Daiwa vinniger is as jy Diesel gebruik, hehehe?Het jy daai reel toe gered?
pieterh
Hy werk weer soos bom.
Thanks Walt
Ek moet net pasop as ek te hard en te ver gooi, dan start daai diesel katrol op en will nie stop draai nie.  :lol:1
Na baie se gewasery met die vrou se skottelgoet seep , het alles weer mooi skoon gekom. Moet se, ek het nie geweet dan van my tackle so goed lyk na die behoorlike was nie.;)
Trophy
Hiya Hanne101,
Knew I was right about the plates...advertising is an amazing thing!
I'm also looking forward to seeing the price...remember to ask the price for Joe Public.
You may be able to make your mate some $$ there are many buggered and scratched reels out there!
Weedeater
Kumz wrote:
Hey Weedeater !!! where are u ???? :fbash ...
Check all my Shimano cuzzies pulled in !!!!  :::S
I'm talking about the Saltist. And I can promise you this, that graphite (Torium) isn't aluminium guys. The Daiwa's sideplates are noted as 'metal' if not aluminium, then what?
Very interesting thread this guys... I also wanna bling my SALTIST!
Just as an aside here...
Introducing Daiwa’s new Saltist™, with the features and rugged “Full-Metal Jacket” construction
Saltistâ„¢ Features:
  • Rugged, all-metal construction with rigid, one-piece aluminum frame [/*]
Weedeater is right... the SALTIST frame is definitely Aluminium, and the SIDEPLATES are METAL, NOT plastic. They have a plasticized coating on it, but underneath is METAL. (And in my opinion, METAL knocks the cr@p out of any Graphite in a fishing reel!. The bottom of the range SL Sealine range of Daiwa's is Graphite...!)
The TORIUM has a Graphite side plate on one side and a "stamped" aluminium (which is not real aluminium at all) on the other side.
Oh, by the way, the SALTIGA has ALUMINIUM SIDE PLATES -
Frame and sideplates machined from solid, aircraft-grade bar stock aluminum, hard anodized to prevent corrosion.
Trophy
Weedeater is right... the SALTIST frame is definitely Aluminium, and the SIDEPLATES are METAL, NOT plastic. They have a plasticized coating on it, but underneath is METAL. (And in my opinion, METAL knocks the cr@p out of any Graphite!)
Hiya Reefman,
Read what you have copied from an marketing blurb. Nobody here has questioned the FRAME.
Agian, thsi jsut geos to shwo hwo good mrakteing is! (your read these jumbled words...your mind sees what it wants to.
The side plates are def not aluminum...my testicals are still at stake!
Hiya Reefman,
(The point being that they are metal and not plastic, nor inferior Graphite)
So for the time being, your testicles are safe.... but the Birthday Bash is coming, just don't bet anything on that !!!
skrops
Ai guys read here
http://en.wikipedia.org/wiki/Aluminium
only way you will settle this is, any who has an old saltist and torium lying around send it to my, I will take it to one of my foundry buddies and get it analysed on a spectrometor. the only way any one of you can be proven right or wrong.
Aluminium is an alloy which is a mixture of different materials such as copper, zink, silicon, varying them gives the aluminium properties in terms of tensile strenght, weight, scratch resistance etc. also make them differently whether it will be casted rolled or forged, but all of them will still be aluminium.
send me those body parts and I will get them analysed.
