how to catch zambizies
Hennie_Smith
how can i catch a zambize in the umlalazi river mouth i'm getting a new reel that can hold 1km of line because my old reel can only hold 300m of line do you think i need it
Nemesis
Nothing will work better than a Fresh Grunter or Kob head,even if they alive they will make good swim baits for Zambo's, a large live mullet will also work.Use 3 strands of Couta wire twisted together,about 1.5m long,and two strong 10/0 hooks.Use a leader not less than 1mm.You will need a reel that can hold more than 300m of line.Fish the river on an in coming tide. Whats your new reel?
khan
AAAH good advice darren
and coming from a guy who has caught two in the last 6 months!!!!
You gonna have to hold my hand and teach me how to get them when i eventually come your way!
Nemesis
Haha thanks Fiaz,im sure we both can learn alot from each other,and im sure we going to pull some fish when we meet up.Hope the summer comes quick!
khan
where you fishing this weekend???
going down to PSJ on saturday morning, gonna try to fish at the GAP!!
Nemesis
Also might be heading down that way Khan.Club should be meeting tomorrow to finalise everything.Maybe we can meet up.
sdunlop
I heard from other experienced swim baiters that using three strands of couta wire (piano wire) is not as good as using two. This being, as explained to me, that three strands may get bitten through since it is thicker and the shark can get hold of it easier, where as two strands will not since they move easier together between teeth and is smaller in diameter but just as strong....
any views on this?
Nemesis
With two strands its easier to kink and break im sure?No matter how thin the wire is,the shark will get hold of it,as it thrashes it head alot!So i would rather be on the safe side and use 3.Just a thought thou
Ziyz
Is there any advantage of using 2-3 single strands of couta wire? Why not use carbon coated/nylon coated wire with the coating removed or 7strand? What breaking strain couta wire do you guys normally use?
:thankie
Nemesis
Howzit Ziyz,the theory behind using 3strands of couta wire is that,it would give you strenght,but at the same time be supple and thinner then 250carbon coated wire.Being thinner,it should be able to pass between the sharks teeth better then the carbon coated without being cut off.However my last two Zambezie's where caught with 260pound bleeding wire and 170pound regular carbon coated wire.Both where bitten terribly,and i was fortunate to land both fish.
Volcom
any views on this?
That theory originated from okes targeting raggies. More along the lines of one using carbon coated wire as opposed to piano wire.
tuna
personally i would just use straight 440lb wire, i have never seen any of it been bitten of , , i retails for around R100 for 10m i think Where do you guys get the heavy bleeding wire the srongest i have ever seen was 210lb
Nemesis
I got it from my from my friends tackle shop,let me confirm the breaking strain on it,it may as well been 210lb and i read it wrong.
