simisteven
I purchased a new Stealth 2010 supalite X and trialled it this weekend.
I found that several litres water drained out of the rear compartment via the bung when I drained the ski.
Is this normal? Should a new ski leak?
Also is the rudder designed within its own separate tube/shaft which is independant of the rear compartment? It would appear logical that some water ingress would occur where the rudder shaft enters the ski. Could this be the cause of water ingress?
