How accurate can you cast?
DJP
The Cape... all of them... have strong winds, often cross shore. Yesterday I went out to fish with my grinder setup with an unseasonably strong east wind. I just couldn't land the bait where I wanted and immediately realised I would not have had this issue with a multiplier setup.
Now for most rock and surf fishing isn't all that important and if you can land your bait in a general area on a good distance you should be ok. Whilst if you are fishing towards rocks, between reefs and kelp beds landing your bait as close to the target as possible becomes super important. Often a meter or two could mean the difference between getting a bite or not, and moreover can be the difference between landing in thick kelp or not! And it's not only about hitting a spot, but line control as well, yes you can feather a grinder but using your thumb to get that bend out of the line with a multiplier just seems to work so much better...
So my question is, how accurate can you cast? 1m, 10m or general east direction... is it even necessary?
And do you believe a grinder can cast as accurate as a multiplier?
Kenty
;)Here is my input on accuracy...I for one ONLY throw spoon and 99% of the time I am throwing for kob...
To me accuracy is pretty important as throwing and retrieving in one spot for say 20 throws and no enquiry , a slight five meter pan left or right you may just hit gold...and yes while fish are always moving , kob , have a tendency to lay n wait in sloepies and rock gulleys in ambush mode , which is their primary function , and here I am biased BUT , multipliers , if you proficient in using them , are way more accurate than throwing coffee grinders...
I know with my SL30 and a 1oz spoon on the end , I can put it where I point my rod and I only need 30 odd meters out...on a 2oz spoon for that longer cast , I can still get my pointed to spot bar any gale force wind , which in that case Im not fishing anyhow...
When my eye is in and I'm in practice, I can cast between a meter and ten off..most times spot on the mark, with a multiplier. Grinder more of a lob in the general direction and feather to slow it down and most times it lands close enough but sometimes flies off to the side LOL..Multiplier more accurate 100%. I was taught to point my elbow where I want the bait to fly with multi, and follow through with everything else, that kind off ensures that the bait flies off in the right direction.
No grinder cast ever beats the satisfaction of getting that perfect load on a rod with the multiplier, the perfectly timed effortless release and listening to the reels' bearing sing as the sinker or lure flies off in the exact direction of where you want it to land, and your thumb just goes into automatic mode and you feather the spinning spool and make that sinker land short of where it wanted to, right on the mark where you want it to..and as that fish that you spotted turns around to take a closer look or that bait gets hit as the sinker hits the floor..its game on! How many times I've cast on the multi and as I click it into gear after a cast and the bow in my line goes straight and my tip just goes DOOOOOOWWWWWN...or I click into gear, let spoon sink for 2 seconds, wind and vas, or let the plug hit the surface, line already feathered in the cast so no bow is there and rod already in the bucket by the time it lands and click it into gear, wind wind and vas! Last time I was out at sea, we came across a bucket floating with a huge loggerhead turtle as its best mate and everyone started casting, casts flying all over the show, I didnt have my rods with and lobbed a spoon out with a borrowed grinder..I think it took my third cast to fly off exactly over and past the bucket, the first two flying off like a bad golf shot...feathered the grinder to make the spoon drop past the bucket and let sink for ten counts, wind wind and vas papa..everyone looking at me in disbelief as they'd figured no fish under that bucket, come on which self respecting dorrie not going to be sticking to that thing like fly to ...anyways got my fry, but if I was on my multiplier I'd have gotten three fish off that bucket in the same time LOL...
That coming from an ex grinderer..LOL I was grinding for 20 years before I learnt to cast a proper reel properly. Glad I did, I can't go back.. A light weight and short rod, aka bass fishing, thats different. Though I am also there pretty attached to the baitcaster my mate gave me and the grinders just been catching carp this year..Caught a bunch of carp on baitcaster, one big 10kg plus broad shouldered mirror was foul hooked on his side under a scale on a crankbait, felt like a 30kg steenie, what a rush I was down to the last turn of line after his first run..
ja kenty, spinning for cob, you can catch them on a grinder sure..but you gotta get that cast in that sloep, between those two rocks, behind that rock etc..same as gallie fishing..there a multiplier comes into its own. And I'm and ex grinderer as stated LOL..
Marthin
Grinder can be controlled, much like kent mentions thumbing a multi. Maybe it is a misspent youth with lots of papgooi in places like Bloemhof, where you create a feeding spot 100m in by landing your bait (mieliebomb) in a 10X10m area consistantly. The smaller you can make that square the more fish you will be catching by saturday afternoon while the trapvas laat hy val waar hy wil crew will still get fish but definately not as consistantly. I am pretty confident in getting things fairly accurate on a grinder by throwing harder than I should and then using my four fingers to slow down the line coming off the spool. I have more often than not either hit the rock or dropped it in front of the rock i am aiming for.
That said we all get those ones that you hold a fraction to long and it ends up sho't left.... Multi is easier, but i tend to push too hard more often than not. Dirk i remember a practice day with SSEC at the big field, where me and jason hit a lawnmower from about 80m with multis.
DJP
Hahaha, lekker old SSEC days!!! Such a bunch of legends!
DJP
Much like Marthin I also started out freshwater papgooing (I actually got Provincial colours in it, the days of yellow hands from SA powder, custard and flourecene). We used bait runners and centre pins and accuracy was paramount, unless you poached fish off somebody else spot or started using TCP or Duiwelsdrek to early and the fish f-off... here we fished mostly 40-120m, probably average 60-80m. I spent hours casting towards a hoola hoop...
I then moved to art lure fishing, here cast were short but you had to land the bait within 10-50cm to get a bite. Especially carp on little SADA grubs... you had to be pin point... I spent many hours at the swimming pool pitching and flipping to objects in the swimming pool...
The I got into fly fishing... really the first time I had to think actively about line control and not just the target. You know, what happens after the cast, how to mend the line and control the drift etc... lekker, but caught more trees and bushes than anything else.
Then rock and surf... In the beginning I was told coffee grinder were for .... ok let's not say that on a forum. It was literally frowned upon to use a grinder. So I learnt to cast with a Policansky 2B and Penn 500 jig master... left handed and overhead, which was fine to catch edibles but you can't cast big baits like that for sharks so I learnt to cast right handed with a proper action, high elbow and big baits. How? Elbe Waverunner and Trini 30, 8oz sinker and half a flip flop sandal to mimic a bait. I might have lost my fingerprints in doing so...
I use both multipliers and grinders for Rock and Surf but for me, when I need accuracy (and thick braid) the multiplier wins hands down.
Fly-aholic
I was raised fishing R&S with multipliers. Mostly surf in areas where there was always side wash viz. Van Stadens, Blue Horison Bay and Gamtoos. So fish moved along swiftly, so accuracy not primary as we mostly went for Steenies, Kob and Belman.
In my teens I started fishing freshwater, club and provincial level. It was here that you learn to cast accurately with a grinder. Even now I still cast overhead if I need accuracy and use my finger with a glove and NOT the bionic finger. Admittedly when I need to cast very accurately, I choose to clip the bait to the lead which help plenty.
I have seen guys like Rean Rademeyer her in Cape Town casting very accurately with bionic finger, so can be done. Especially here in Cape Town where you need to be very accurate for gallies. Admittedly the gallies are very close most times.
Kenty
;):cool:could not have said it better...
SPARRABOS
Vir galjoen vang moet jy op n tiekie kan gooi. teen n riffie... Teen n klippie... Langs n Rotsie...deur n nekkie... Dis hoe ons geleer is met n Penn katrol... Multiplier. Spot casting. Dan is daar ook daai dae wat ons in 80 km uur wind vis. Jy gooi heeltemal na regs.. Waai wind hoek en sinker Dat hy voor jou Val.. Lol... Dan vis jy waar dit oop is voor jou in n skuim massa... Lyn waai bak... Daai vis trek bak lyn reguit..
Dit is soos golf, hoe nader jy die bal aan die pen kan kan slaan, hoe groter is die beloning :dban::breakd::dban::breakd::dban::breakd::dban:
Maar jy moet weet waar die pen sit :spite:fswim:spite:fswim:fswim
rbacht
Nothing better than aiming for the hole directly in front of a rock. Then sending the 3oz into the front of the rock and it dropping right where you wanted.
Nothing worse than hitting the same rock and the terminal tackle disappearing over the back of said rock....
Mike Smith
Spot on! I feel like this post was aimed at me! I am a sucker for overcasting and losing terminal tackle in rocky areas!:?
Mike Smith
Nou die twee manne het mos BSC grade in spooning! Hulle kan 'n kersie van 'n roomys afhaal met n 13 voet stok en 'n grinder!_seal1_
