Some foam to tie to your hooks and a couple of the big foam floats that you can thread your line through to lift your bait and make neat chokka baits.
The advice above for all the other sizes. I would just get a couple of smaller hooks to catch a few livies with as well.
Shad season will be open. Get a few Bandit 6 & 7/0 longshanks as well, and 2 packets of ready made 6 inch and 12 inch steel traces. I know the aren't so strong as self made, but unless you just wind wind no drag they will hold an elf.
Use the 6 inch steel if you target fish with a sardine or sard chokka combo, as you can hide the trace inside the bait and it won't put off the kob. I find the ones with the clip in snapons better, as you can take the snapon off, thread a "skelm" hook on, put the snapback back on and put on your main hook.
I don't like foam in my bait. I put one of the big foam floats on, not the 1cm thick ones the fatter ones, by pulling my trace line through the float with a needle. Then put a toothpick into the hole and stick through so its inside the float next to the line. Tie both ends of the float as tight as you can with 2 small cable ties. After you bait is on you just slide the float to about 2cm above your bait. Works very well if you make a chokka blob bait to lift it just above the pesky crabs, as you can't have foam on your hook with a blob bait.
Best of luck send us the pictures of the big one.
