HOOKS FOR PYLIES
Angus
Since landing my first pylie 2 weeks ago on a 11/0 hoodlum, I have subsequently lost 2 more due to pulled hooks.
I would prefer to use circle hooks, but due to the fact that the pylie sits on your bait and chews and swallows it, I am not too certain if a circle would be the answer. My first one that I landed was hooked deep and I had to cut the trace...but it was solidly hooked.
With the size mouth the pylie has...would circles work...and if so what sizes?
Any advice?
I had a Black pylie take a whole bonnie (1.8kg bait) while it was still on the way down the slide.
Viskoning caught his 150kg on a stocking filled with 1/2 occie, 2 bonnie heads (big) 1 Tail body and some sards.
They can swallow a big bait and I saw Big Fish Compatible and Tuna's post on their Pylies and Duckbills they caught at the beginning of summer and they sommer had 1 x 20/0 circle int he rig.
I reckon that going for Pylies you should be going big or going home. We know it's going to be a Bosbus so you want max tackle. I would probably target it with a 14/0 circle.
I find that even a 50kg diamond swallows a tail head with 2 x 10/0 inside before you feel he's on (using a slide bait).
They lay on the bait, chew and swallow the bait and then move off so a circle should result in less gut hooking
They have awesome jaws with a wide bony plate so if you get hooked on or around the jaw a 14/0 - 16/0 will get purchase around the jaw and not with the tip on the jaw which will result in pulled or straightened hooks.
Angus
Thanks Enigma...tried yesterday with the circle I use for smoothounds ( 1st on left in pic)...but had no more pickups.
I have now hauled out these other 2 sizes....will they be suitable...have my doubts as they are a very thick guage circle?
The circles Tuna uses for his black rays are bigger than the one on the right.
If you have a 500gr bait then a 30gr hook shouldn't bug the Pylie
Arno Nel
Do the mod to the Cricles like Trophy explained and you will see the difference in pick ups. I am currently modifying my circle like that.
Tuna and Trophy are the Circle experts in my books so get hold of them and ask them for adice on which one sto use for what fish. I would think that bigger is better but by modifying the hooks it can make all the difference one requires.
steve m
I use and seen 11/0 kenals being used by some awesome fisherman for black pylies and i have only ever once had a hook pull and that was with a hoodlum aswell
aquadementia
I would only recommend circle's for rays BECAUSE they come and sit on your bait and chew on it for a while. I've lost too many pylies to pulled kendalls but never to circles
Angus
Bought a pack of 20 Mustad 14/0 circle today. The biggest I have is this one...
