Guys
Problem halfway solved, why halfway, well here's the thing you want (I Think) but you'll have to have it shipped from overseas..... EISH!!! But check it out, I coiuld not yet find anything on the scientific facts regarding the effects of things like Q20 on hooks yet, but will post it when I find it.
Speedy-Reel:
The many applications: Speedy-reel’s proven rust and corrosion properties, make Speedy-reel a multi-functional
oil that can be used on any metal surfaces to prevent rust and corrosion.
Use Speedy-Reel fishing reel oil on your: reel, spool to decrease line memory, swivels, hedges, spoons, lures, pliers, and fishing knives. Speedy-reel’s formulation of fish attracting scent and low viscosity, rust and corrosion prevention oil is the “all-in-one†fishing reel oil to use.
It’s the only fishing reel oil and fish attracting scent in one. It should be the only oil you use on your fishing equipment.
Order Speedy Reel
How to apply:
Speedy-reel. Cut the tip off of the spout top. Apply a few drops of speedy-reel to the inter-workings of the reel; spool, and reel handle for reduced friction. Apply speedy-reel to your line to reduce line twist. You can also apply a few drops of speedy-reel to any metal surfaces to eliminate rust and corrosion. A few drop of speedy-reel in swivels will also
increase the swivels ability to spin. You can use speedy-reel on your fishing knives, pliers, spoons,
hooks, or any other metal surfaces to maintain quality-fishing equipment.
Here's the site I found it on:
http://www.scenttec.com/Many%20uses%20of%20Speedy%20Oil's.htm
Hope it helps
LGF
