(Sorry -- this is a duplicate of what I put in a forum elsewhere on this site, and only afterwards realized that it should've been here.)
I can't figure this out: my Daiwa SL30SH was working fine, and then the drag started slipping (presumbably after I'd serviced it): no matter how hard I tighten the drag, it's just about strong enough to reel in a lure. Any extra pull, and it slips.
My first thought was that I must have gotten oil on the drag washers, or that a part might be missing. I took the reel apart, cleaned the drag washers in paraffin, washed them in detergent, rinsed them, dried them and reassembled the reel (without drag grease). Also, I checked against the exploded diagram that all the parts were present and correctly assembled. Still no good. I then stripped it again and put some drag grease on the drag washers. No difference.
I've also taken the reel to a competent reel serviceman. He stripped it and reassembled it, and could find no fault. Just to make sure, I bought new fibre drag washers from him and replaced those in the reel. No difference.
Curiously, after taking the reel apart and reassembling, the drag seems to be fine. But it soon starts slipping again.
This is driving me nuts. These reels aren't that complicated. And I've stripped and reassembled this thing a dozen or more times with no luck (I also use and service an SL20SH and and SL50SH without problems -- so I doubt that I'm just being dumb).
Am I going to have to replace a reel that's in perfectly good order because I can't find the reason for this malfunction?
Please: has anybody had a similar problem and solved it? I'd love to hear from you.
