Hi Looking for some pointers on a rod to  pa
MantaRay
Hi
Looking for some pointers on a rod to  pair with
Saltiga Dog Fight SA-Z6500HDF reel.Will be popping
and jigging in Bassa's.
Nepptune
Hey Manta,
Are you looking for a rod to do both popping and jigging with, or two separate rods?
I would certainly advise getting yourself one of each, especially when heading to a place as full of big fish on both jigs and poppers... A jigging rod can toss a popper a short distance, but not enable you to achieve the distance and action you'll want, and you can jig with a popping rod, but you are going to be hurting bad after a short time as the length makes life tough when jigging, especially anything over 200 grams!
We have a couple jigging rod options for you, that are cartainly built and designed to klap the snot out of the big nunus that Bassas will deliver!
A couple suggestions:
Jigging Master Three Kings Special:
Length: 5’3”
Pieces: 1 Piece
Jig Weight: 250-500g
Line Rating: PE4-PE8
Max. Power: 33Kg at 50 degrees, 18.5Kg at 90 degrees
Ocean Revolution 10000 Series
Pack Length: 1530mm (5.0’)
Pieces: 1 Piece
Weight: 265g
Line: PE6
Lure: 200g-400g
Maximum Drag: 18 kilos
Both rods are top of the line fish fighting machines, and will do the reel, and the fish in Bassas justice!
When is your trip?
Nepptune
Hey Reefs, thanks for that mate, much appreciated, I was writing same time you were! :)
Manta - The Saltiga DF is defintely up to it mate!! Superb reel!
Its a dedicated popping reel, so is higher geared than a dedicated jigging reel, so will be a little more hard work when jigging heavy jigs, but its a superb piece of equipment!
If you have the opportunity to upgrade the drag washers to Carbontex before you go, thats even better! You'll get a longer lasting smoother drag, and when you are in an isolated place like Bassas, you want to be sure your gear performs PERFECTLY!
Nepptune
Hey Manta,
Super jealous of your trip mate!
We may have a few more options for you by May as well, both on the jigging and Popping front....
We'll keep you in the loop on new arrival products with a fantastic line of Popping rods coming soon, that will be perfect for your trip, as well as a few more spinning options on the jigging rod front.
MantaRay
cool , I am from Durban will my local Kingfisher or Basil Mannings be able to do the upgrade ? Or is it a send away wait a few weeks epic I need to go through.My goal is to land that elusive 30 kg GT once done , pull out the light stuff and have some ripping fun.My Saragosa is going to bleed the red dye out the spool.
Nepptune
Reefs - Mate, you know me bro, Stella FA is where my heart lies!! :) All 3 reels are incredible, but I think the Stella FA has the best proven track record... the new SW is awesome, but I've not had the pleasure of fishing one...
Haven't fished the DF either, but its certainly got its followers, and has knocked some monster fish on the head in its time.
Manta - There is a local Smooth Drag agent, Darius/Whaler who could probably get you the drag washers, otherwise you could order them from Smooth Drag directly www.smoothdrag.com and order from Dawn, she's a legend. The washers shouldn't take more than 2 weeks to get to you, order some Cal's Drag Grease as well, and you can do the upgrade yourself, or get Basil Manning to do it for you.
blaasoppie#1
Not too impressed with the Stella SW; my mate just got one and the gears don't sound too good; i have the SW20000PG, SW8000PG (Japan models) and they are the bomb. I also have the 10000FA, 8000FA, 4000FD, 3000FD and they are awesome reels.
Next purchase is going to be Stella SW10000PG to match my new Blue Rose S517F that is on the way.
Blaasie... run through the PG - FA - SW differences please? Japan models??
Also... am I right in saying the 18000SW AND THE 20000 are same size as 20000FA
Then the 8000 and 10000SW same size as the 10000 FA?
If you had to buy a 10000 size reel, would you go FA or SW?
David Sharples
PG (Power Gear) = Low gear for jigging
HG (High Gear) = High ratio for popping
FA was the older blue Stella from the US
SW is new 2007/8 model
8000 & 10000 SW are the same size body as old 8000. The 10000SW takes slightly less line than the old 10000FA. 18000SW is HG for popping, 20000SW is low ratio for jigging.
All very confusing!
Definately fit the carbontex to the Dogfight. The factory washers are really sticky.
Mark - What happened to your mates Stella?
blaasoppie#1
Not that i am an expert in any way, but apparently there is no difference in the gears of the SW and the SWPG (i thought there was, but i read a good report on the hulltruth forum where the guy said that he has taken both apart and there is no difference).
The difference appears to be in the gear ratios.
SW8000PG has a 4.9:1 gear ratio (PG is power gear)  and drag is 25kg
SW8000 has a 5.8:1 ratio and the drag is 25kg.
SW10000pg gear ratio 4.9:1 drag 23 kg
SW10000 gear ratio 5.8:1drag 23kg
SW20000PG gear ratio 4.4:1 drag 25kg
SW20000 gear ratio 4.4:1 drag 25kg
The SW's have different gear materials compared to the FA's and some other upgrades.
I still like the FA's a lot, especially the 10 000FA; it is really a solid reel.
My mates SW20000 may just not have been lubricated properly from the factory, but i will continue to purchase the SW PG's even though i cannot read the Jap manuals and have no customer support.
There is a really good article on http://www.360tuna.com on servicing a 8000FA; took mine totally apart and serviced it at work the day i was going fishing in between working on the computer and trying to make it not too obvious.
I have been through too many Stradics, baitrunners, spirexes etc. buy a Stella and you will have a machine that will perform flawlessly and outlast 10 other reels.
Have to get back to packing for tomorrow.
blaasoppie#1
Nice post on the Stella service Reefman; i love those reel service posts.
My favorite part of putting the reel back together is the roller clutch springs; those little suckers just want to jump everywhere. I don't like putting grease on the roller clutch assembly, just a light dash of WD40.
I hope Manta got sorted on his rod; strayed a bit off the topic.
Ja sorry Manta... bad hijack this one! But hopefully it's all good info.
Those roller clutch bearings... hmmm I learnt the hard way! too much grease - she not like!
David Sharples
http://www.stripersonline.com/surftalk/showthread.php?t=647666
Off topic and sorry for the thread hijack but this is the most thorough review of the Stella SW I have ever seen. Great for all those reel geeks out there (Mark?) haha
I only skim read it but wow really great depth of detail.
Interestingly apparently no difference between USDM and JDM Stella SWs...
blaasoppie#1
Hey buckwheat i already read that article;he would not know if the gears were made from a different metal just by visual inspection though.
