kitefisher
Great stuff Werner,well done.
Congrats!
Could you see your popper at all to detect the takes?
I made a popper with a big glow bead threaded onto the wire, but yet to try it out at night.
It should work a charm and one can "recharge" the bead with ones headlamp after each cast.
Hi PH,
Do you make use of a pumkinseed or do you have bait (grassie fillet) below your popper?
Alex123 wrote:
Hi PH,
Hi Alex
I mainly use Pumpkin seed slow sinker white(in the vaal dam and river). I have used loodkop also, but best result still with mad pumpkin.
Attached photo of my rig. I keep it simple as possible.
I use gummy stops top and bottom so that I can set the depth according to conditions, also use a big bead against popper to prevent gummy stop getting stuck inside popper.
Dankie PH...
My rig lyk baie dieselfde maar ek gebruik 'n draaispil ipv "gummies", met my pumpkin seed so 50cm onder my "popper" (rooi kurk prop - shad). Tussen my draaispil en my pumpkin seed het ek twee glas krale sodat as ek dit "pop" klap hulle teen mekaar - hopelik werk die ekstra lawaai onder die water... Ook my hoek op die pumpkin seed verander na 'n enkel "inline" hoek... Ek het nog net regtig een keer kans gehad om dit te probeer maar daardie dag wou die weer nie saam speel nie... Gaan volgende naweek Vaal dam toe en dan gaan ek dit beslis weer probeer.
As jy nog enige advies kan deel sal ek dit baie waardeer.
Groete.
::jest
