My advice is use the 12ft rod on the pushing tide, when the fish are really going to start coming on the bite. On the low tide when you get get very far forward use the 9ft rod to scratch around. Speedmaster is perfect yes. A sensitive tip just helps you feel the bite of the fish better, so is important as the fish will bite shyly if the water is on the calm sidecool cool. I have o,45 mainline, that should be fine though... i want to buy myself a speedmaster ASAP and load it with 14,4 kg Double X. Should serve me well... What do you guys mean by a sensetive tip??? something that flexes fast?? i have a small blue marlin 9ft rod which is strong enough and i can cast maximum 70m with it(i got out that cracker on that rod!! haha i thought it was gonna break!), and then I have a 12 ft blue marlin rod that is quite flexible but strong.... Should I use the 12ft with my jigmaster?? usually I use my 9ft rod with my jigmaster for small edibles but for gallies I need to get slightly deeper. so the 12 will be better???
Nee, maar ek het my van my skool dae in n afrikaanse skool gedoen, so ek praat vlot afrikkans. Dis nie te se ek hou daarvan om dit te praat nieok right, sounds good. thank you for all the tips!! Is jy Afrikaans???
It should b ok. If your rod can handle a 5oz sinker it would be better, as you'll be throwing in rough water, so you don't want your sinker drifting all over the show till it gets snaggedok, english haha. Will a jigmaster balance on a 12ft rod??? If i use 13,6g line with a 4oz sinker and a 12ft rod??
Hmmm, now thats a familiar website...! Whaler?! Where are you?Read this found on the website.... http://www.gardenroutefishing.com/
100% right![color=#006600]Grunterrr[/color] wrote:in the white foaming water, probably not more than 10 metres.Hi Dynamite, sorry to bother again, but you really know whats going on! how far is far??? at that spot?? how many metres wouldyou guess??? in the lively water near structure right??? What thickness line do you use and what sinker???
thanks(hopefully you can reply!!
Chris
If the water is right, and they are biting but they arent taking the bait, should i change the presentation of the bait??? or what??? Look for wilder water??
