bos suzi wrote:
Thank you Willem,
So should I rather be throwing lighter sinker?
Like a 4 oz?
Or should i just be practising alot more?
I attached my gopro to the rod, a d you can really see it bend and load quite decent, but on the video it really doesnt look if the tip of the rod is working that great, perhaps the energy in the tip if released at the who d time with the wrong timing in releasing the spool with my thumb?
That is the reason why it is not advisable to rush. Bend has to be developed and constantly added on thru the various motions I mentioned. Line is released instinctly by the thumb when it is not capable of holding anymore pressure OR when your rod is aligned 45degree to your preference. The sinker will not fly too high to tell you this as a 1st-person view. Only your friends can observe from side OR can be seen from when the rod starts recovering when hitting it.
Ideal scenario is after hitting, the bend is there. This is a very subtle detail that can be observed from side view. It is easy to claim a rod being soft after seeing bends when the rod is vertical. Reality is, pulling it further can still generate more distance.
For power loss from body rotation, sinker bounce or lifting the rod too far off early in the cast, the camera at back will help you on this.
I think this will take sometime. Once all these are in place, you have conquered the rod and will end up with a good pendulum cast in very short duration. Could even be 1 day if someone who swings sinker teaches you.
Heavy sinker builds strength, small sinker makes you explore techniques to generate speed. My take will be heavy sinker as I have seen it improved my cast and magnify mistakes. Casting 18g and 175g requires different technique, it can be learnt and fine tuned to suit yourself. No 2 person will cast the same manner because everyone is built differently. Derive power and speed from the basic cast to suit your capability.
