Ek neem aan hy sal so lank in die water hou soos 'n soft float. Hulle voel nogal baie dieselfde al verskil is net dat die bleeding float so poeirigheid buite aan hom het. Ek sal dit bietjie moet toets en jou presies laat weet.wmpruis enige idee hoelank so bleeding float aan hoek in dam/water bly ??
To be honest, I suck a bit at this whole "kolgooi" thing. Some guys gooi kol with one rod while the other is used to try and get fish a bit further out. Some guys use both rods on one spot... So its up to you. And it also depends on the venue and the type/size fish you want to target.Thanks for the advice Naruto another question that I've just got to ask, if you don't mind.
When making a spot/kol do you make 2 separate spots for each rods or do you fish both rods to the same place and make 1 big spot. With specimen fishing we usually fish just off the spot but we use a different rod to make the spot so I presume with this style of fishing it will be on the spot or as close as possible.
Regards Tyrone
tyrone mclaren wrote:To be honest, I suck a bit at this whole "kolgooi" thing. Some guys gooi kol with one rod while the other is used to try and get fish a bit further out. Some guys use both rods on one spot... So its up to you. And it also depends on the venue and the type/size fish you want to target.Thanks for the advice Naruto another question that I've just got to ask, if you don't mind.
Regards Tyrone
En hier dink ek jy is die kolgooi meester LOL! ::respekt:Haha! Ek begin gewoonlik so:Naruto wrote:Âtyrone mclaren wrote:To be honest, I suck a bit at this whole "kolgooi" thing. Some guys gooi kol with one rod while the other is used to try and get fish a bit further out. Some guys use both rods on one spot... So its up to you. And it also depends on the venue and the type/size fish you want to target.Thanks for the advice Naruto another question that I've just got to ask, if you don't mind.
Regards Tyrone
wmpruis wrote:
Haha! Ek begin gewoonlik so:Naruto wrote:tyrone mclaren wrote:To be honest, I suck a bit at this whole "kolgooi" thing. Some guys gooi kol with one rod while the other is used to try and get fish a bit further out. Some guys use both rods on one spot... So its up to you. And it also depends on the venue and the type/size fish you want to target.Thanks for the advice Naruto another question that I've just got to ask, if you don't mind.
Regards Tyrone
Eerste cast is so 80m...
Tweede cast is so ver as wat ek kan gooi...
As ek vis kry op 80m is ek happy...
As ek nie vis daar kry nie kyk ek rondom my waar die manne wel vis kry en pas daarby aan...
Ek sal dan daar waar die vis uitkom probeer n kol opbou...
En afhangende van wat die manne se tempo is rondom my sal ek dan daai tweede stok of nog verder probeer gooi of ook op die kol cast...
As ek op die verder stok vis kry gaan ek elke keer met altwee stokke cast tot daar, weereens afhangende wat die korter stok se tempo ens is...
