I quote from a tester...
"Also had a couple of casts with that sardine you gave me...... Bud, that thing is a winner, and If I had stock on the beach, I would have sold out!!!! If you think the action in your pool was good.... you should check it swimming in the ocean!!!!! BEAUTIFULL!!! By just changing the rod position and retrieve speed, you can use it in several different ways. I found it to have a great surface action when wound in fast till it surfaces, and then slowing down to speed just fast enough to keep it on the surface. It also works nicely with a sub-surface walk the dog retrieve (rod tip down, twitch, slack, twitch....). Then there is the straight medium speed retrieve that makes it swim like a lost and lonesome (bulseye) sardine!"
This by the way is the 3rd modification. The first ones I made swam kak till I got the ballast/buoyancy right.
But I really need my boat so I can hopefully get fish on it!
I'll try and do a video, lets see, will be short clips though.
