Henning Venter Casting Clip
JFE
Moet barm maar vêr wees hoor, want dit vat jou van 10:24 tot 14:27 om kaar te kyk, hoop ek het genoeg lugtyd om die hele saga te kyk :hyst:
Bevid
JVW wrote:
Hoe ver gooi Henning-dit voel soos 'n ewigheid wat daai katrol spin
I'm speaking, or should I rather say typing under correction. I recall something like 170m plus. He does however have a "massive" advantage.
(Sorry Henning. Just could not resist)
Marthin
Dit was baie ver.....baie baie ver..... Daai is nie n rugbyveld nie maar n polo veld.
Toe hy die eerste keer gooi, toe dink ek "die perd gooi darm skeef".... toe die sinker val, toe verstaan ons hy was nie lus om die ding tussen die bosse aan die oorkant te gaan haal nie.
JVW
Massive, as in Boepens?
thenack
personally, casting isnot my problem, not getting an overwind is....need GPro footage of what he does to prevent that...
its how you see it or take it.... it is a masive advantage in catching fish!!!:fbash
or
the 120kg behind the rod!!!:fbash
abughalib
I agree. I also don't have a problem casting, but every cast ends in an overwind. Luckily i have become a bit more competent in getting rid of an overwind. If someone can show me how to prevent getting overwinds i would appreciate it.
Bevid
Try tightening the spool tension cap untill you gain more confidence.
KLIPVIS
Henning ek was saam met jou Luca toe jy gemeet met n tape measure 197m gegooi het , en dit met n gewone stok en torium 30. so ja as iemand wou weet hy gooi polisie ver
kaspaas
I also had this problem when I tried to really give it a go. Tightening the break is one way but not ideal as it limits the cast a bit. The real answer is to install a MAG-IT cast control system. Pm Old Salt (Jonathan) or Cuban Cigar (Wilhelm) in this regard. They both install it but I think Wilhelm is the one that imports it.
I had it done and I can absolutely recommend it. My casting distance has increased because I am no longer breaking the spool with my thumb when casting and I simply do not get over-winds anymore.
my persoonlike gevoel oor die magnete is soos volg.
ek verloor distance met die trini DC..... , maar love die katrol in die nag.... hy maak gooi definitief baie makliker.
Jackal
Henning, hier is n vraag vir jou. Almal weet jy kan ver gooi en jy het gooie leermeester gehad. Party mense dink dis omdat jy "n big advantage" het, maar daar is baie manne wat selfs groter is as jy en hulle gooi nie naastenby so ver nie. Wat volgens jou maak dat jy so ver gooi met betrekking tot die styl van gooi wat jy gebruik? Dink die manne sal dit waardevol vind.
se jy ek is vet jacques?
dis alles tegniek.... lengte help met lengte van stok....
maar ek kan wel se.... my lae rug is redelik opge-ellie!!!
