help !!!!!!!
Fisherwoman
i have a 55hp mariner motor, the motor works fine the gears are turning but the propeler does not turn, i dont know if u need water pressure for it to turn or if there is a problem between the gear shaft that is connected to the propeller, pls help !!
pieterh
Hi Fisherwoman
First , where you from.
There is a few metheds.
1.Without starting the motor:
2.  turn the prop by hand and check if the centre nut   holding the prop also turns.If   the nuts does not turn, your rubber in the prop has sheared off.
3. Put the motor in gear, first forward and then reverse, can you turn the prop by hand if in any gear?
Try those simple ways and see.
It can be that U need to set you linkages to obtain foward and reverse.
I fall these dont work, it sounds like the dog in the gearcasing is worn out. Need to strip the gearbox and replace the centre gear(dog) for the selection.
Let me know how it is going and will help where I can.
Piet
