Hello Guys,   I was wondering if a
kraken
Saturday is out. Got our last shore angling league so I'm gonna be burning diesel that I can ill afford chasing critters that eat baits made up to look like granma's sunday roast.
But sunday looks good.
blaasoppie#1
Nepps,
I have one of those Runbou Snr's for you and Tackle whore; will bring them down at the end of July.
You will have to swop one of those Wahoo's :)
This dude that i buy my lures from had some Fisherman poppers that are about 30cm long; biggest poppers i have ever seen!
Nepptune
Mark you're a legend mate, will happily swop you a Wahoo or Ulua for one of those Runboh SNr's to add to the collection!!!
fedu
kraken wrote:
Pretty sure those yfin would also enjoy a hit of that stickbait candy!
After seeing Arno's yfin on the Roosta popper, I'm finding myself more and more drawn to climbing outside the box and fishing exclusively with artificials.
I just need to rob a bank or win the lotto!
Lemme know about Sandvlei. Would dig to see some of that gear in action.
Wellcome to
THE road to perdition
::S
tackle whore
OH boy you buggered now mate !!yellows love stickbaits orion tropic 150 and wahoo 100 blue/green mackrel work in the canyon as well as flapper 130 . if you hear screams at 35 05 its me getting smoked .
mordecai3004
those stick baits look awesome the prices just dont fit my pocket at the moment but i suppose you only need one, or two ,three just in case and a fourth cause that other color looked insane lol
vis blik
Guys take standard halco, push lip pin out, remove lip glue a shaped lead in  the cavity (or use solder) add 2 single hooks and work with an erratic wind and stop. I   have had great success with YFT up to 40kg. You can throw easily with spinning reel and braid. dont be afraid to leave lure on top motionless for short periods that is when it gets blasted!!!! I often use in conjunction with baiting or when tuna are feeding on top. For slightly heavier lure grind away plastic lip of floating rap-they are made of wood.
Hi,
Generally with stick baits, they are tail weighted for casting... Do you add weigh to to the tail to help them cast better? Or else they spin and you also don't want them to be nose heavy or the hooks tangle with the line.
Sounds like a great plan!
Dingleberry
I recently did a Maldives trip and ran out of small stickbaits. The only lure I had left in the size range had a lip, which I cut off. It turned out to be a fish killer!
Dingleberry
vis blik
yes you do have a problem casting from time to time but the extra weight in the front when twitched causes the head to bury and splash and resurface. I have a couple of the Aussie stickbaits which do cast and work well on heavy tackle, but at R300 difference in price a cheaper alternative  in some conditions works better. Try casting downwind for better results. Not trying to dis stickbaits just offering cheap alternative. Will post details of Cheap stickbait (R90) when stocks arrive.
Dingleberry
The lure I chopped up was a small Shibuki, which has a shifting weight to aid casting. The weight then moves forward on entering the water and is held there by a magnet. I suppose that not having the weight at the back reduces stability and improves action?!
vis blik
Exactly. The plethora of nylon rear weighted plugs only work for yellowtail and garrick. I have changed the shape of these lures to change the action with great results for these species only (useless on tuna). Absolutely sold on stickbaits. I subscribe to Bluewater mag Aust. articles there where marlin have shown big interest!!!!! Imagine casting lures at free swimming marlin
Dingleberry
That would be awesome! I reckon hookups would be few and far between though. I have had sailfish hit a stickbait about 4 times now and not a single hookup. Frustrating to say the least.
Nepptune
That was an expensive excersise Dingle!!! You know they come in a bibless version hey??? ;):fbash
I've had one solid Hook up on a big billfish on a DarkStar Wahoo 125 in Madagascar that left me in second place quite emphatically...
Smashed at last light, and got smoked for 200 odd metres off 12 kilos plus of drag on a Stella 10000FA with me nearly getting pulled off the back of the boat ( a dive boat with an open transom, thankfully the skipper grabbed my belt!
5 or 6 jumps into the sunset and all I was left with was this...
170lb FISHERMAN STEALTH leader pinched through, and scuffed up to hell and back...
:wfish
We are releasing a new DarkStar Stickbait in July, which has taken a few Billfish recently... the trick is in the hooks set up... alot of guys who target Sailfish in Ropmin Indonesia, which is primarily a casting Sailfish fishery, have done huge amounts of testing into best hook set ups on stickbaits, and most use 2 x Assist hooks, one off the belly, one off the tail, to give themselves the best possible chance of a hook up in the hard mouths..
Here is a Video of a Marlin taken on one of our soon to be released Sticks. Notice the Hook set up..
http://www.youtube.com/watch?v=HsVVJ6DBjqU
