Hi there apnearules,
Here are some of the weather sites I use to check on launching potential at Noordhoek. I usually check them all. When they are all 'singing the same tune', in other words, they all agree - then I'm happy. When they are all telling me a different story, well, the only way is to get up and go and look outside on that particular morning.
1.
Skiboat report - Plett to Cannon
2.
South African Weather Service
3.
Synoptic chart
4.
Windfinder for PE
5.
Surfline (check out the sea level pressures here)
6.
Pressure & pressure history (don't go out if massive drop in pressure suddenly - cold front coming!)
7.
Buoyweather (the most accurate usually)
8.
Magic Seaweed
9.
Windguru (Seldom accurate!)
The
pressure is very important as it'll tell you what the wind is going to do. Look at the synoptic charts & the synoptic predictions on Surfline (sea level pressure charts). High pressures rotate anti-clockwise & low pressures clockwise. Pressures of about 1015 and above are 'high', pressures below about 1008 are 'low'. All the lines around the pressure cells (called isobars) will show you the general wind trend if you picture them to be rotating with the pressure cell. If the isobars are really close together, there is a large pressure gradient and therefore lots of wind. If they're far apart, there is likely to be light and variable winds.
Then check the
wind charts. Easterly winds - I stay in bed except for light North easters in winter as these are berg winds and quite nice to fish off of Noordhoek in. Be careful, NEasters OFTEN turn into Easterlies by 11:00am. South westers, Westerlies & North westerlies are fine on the wild side up to about 15 knots if there is not a large swell running. Anything more and the sea turns grey and starts 'shifting' from the west. Not very nice!
Then check the
swell. South easterly swell (predominant in summer) is chunky, lumpy swell 'packets'. It is caused locally by strong south easters and usually doesn't last long (a brisk west can flatten an east swell in 6-8hours!). Usually fishing in the east swell is gut wrenching!! I like to look for a long period west to south west swell - say 11-15 seconds. The size usually doesn't bother me unless it's low tide and the waves are breaking across the launch gully. A note from my surfing days near noordhoek: big west swell = massive west to east current in the launch gully (I have been swept down to the lookout carpark and beyond on more than 1 occasion!!) So be careful if launching through waves in the channel. Watch your position very carefully if you're moving slowly out, through the waves. The reef to your left is known as 'Rocky's' and is super shallow with waves that suck dry before imploding!
Another interesting phenomenon is that you can have various different swell directions running simultaneously! Check out Magic Seaweed and click on an hour that you'd want to go out - say 05:00am sat morning. It will give you the 'spectral breakdown' of the swell components. So you could have loads of sites telling you that there is a 3m WSW swell running at 11secs, but you get out to sea and there are these small chops that keep you from running as fast as you normally can.. These are the smaller swell components - see attached image for an example.
Then, there is another massive bonus!! : Noordhoek skiboat club has got itself a weather station & a video camera that you can log into from your bed!! R65 per year - what a bonus. Wake up in the morning, hit refresh on the PC, check out the sea & the wind at Noordhoek and then make the call to go or stay! Check out http://wildsidedivers.co.za/wildsidedivers/login-form.php
Anyway, hope that helps.. let me know if you have any questions?
RandomBrad.
