Guru's using Windguru.com
The Boatman
Hi Guys
I've been studying windguru.com for the last couple of days. I know I'll probably learn some of this stuff when I do my skippers in Oct but I thought I'll ask you guys anyway.
What windspeed and wave height do you guys consider to be the max for small craft to safely launch from Noordhoek?
This way I can sit here in the middle of the desert 9000km away and study windguru.com and see if you guys will go fishing or not...lol
Cheers guys and tight lines:wfish
MouseDog
Windspeed is not my major concern, I usually decide by looking at the swell size and time, for instance if the swell is 4.5 metres and the period is 9 seconds, there is not a chance that I will dare to go out, even if there is no wind.
Normally I take the time between swells (in seconds) and devide it by the swell size, if the answer is less than 5, it becomes dicey.
If the swells looks good and I do go out, I check what the wind will do later in the day, I'll rather run into a headwind when going to my fishing grounds than when I return, that is how I decide where I will fish for the day
The Boatman
Thanks MouseDog
That makes a lot of sense. Dumb question.....I always thought the stronger the winds the bigger the waves will be. Is there a relation between wind speed and wave height or more influence on wave intervals?
Cheers for your advise!!
MouseDog
It all depends, around here a strong westerly tends to flatten the big swells, but makes the water extremely choppy a easterly will produce the BIIIIG swells. In general, if the wind is blowing from the shore towards the sea, it will flatten the swells, when it comes over the sea towards the land, the swells will be big.
gerritp
You got it the wrong way round, westerly will give you big long swells, easterly will give you choppy sea's. Hover if the westerly is really pumping you will get a chop on top of the big swells, than you are realy k@k sea's, tends to happed a lot at Recieve, Oesterbay to Cape st Francis and the SWG.
As for Noordhoek, any westerly less than 15 knts will be ok if it was preceded with a night of little to no wind. If the wind did blow during the night, best will be to have a look at the sea to see for your self what is going on. As for easterly, i stay home if its anything more than 10 knts, the sea becomes choppy, water temp goes down and you tend to catch a lot of nothing.
Hope this helps.
The Boatman
Thanks gerritp
It is nice to be able to rely on the experienced hands out there!!::respekt:
I'll remember those numbers and try and build up some of my own experience and maybe one day I'll be an sucessfull and experienced skipper!!:D
Cheers and tight lines:wfish
MouseDog
Hope this helps.
I totally agree with the easterly, if it blows, you stay away, but in the limited experience that I've got, yes, the westerly messes up the water around Oesterbay and Cape St Francis, but the moment you get into the bay between St Francis and Jeffreys, it seems to be much flatter with a westerly
gerritp
I must just add that we caught really nice fish in easterly winds before, most memorable would be the 7.5kg elf/shad. Most of the time you will catch very little in the easterly.
When i get down there again i will give you a lot of marks for from Sardinia bay to Recieve, its on my GPS and the boat is at my fathers in Uitenhage.
gerritp
Hope this helps.
100% correct, easterly come directly from the open ocean, nothing to shield the bay at st Francis or PE from it. Westerly will be blocked by land at Cape st Francis of Cape Recieve for PE.
If you are in the bay, anything less 20knts westerly will be ok as it will be flat, easterly you will be all over the place
MouseDog
Same here, got some great Red Roman's, all 3kg +, at Mostertshoek whilst lying on anchor waiting for a bad easterly to go down.
Speaking of marks, I had about 50 marks on my GPS when it decided it does not want to work so lekker anymore, nothing major, just a very "dof" screen.  I sent it in to Garmin to have it fixed as it was still under guarantee.  They were so kind to replace it with a brand new one - Marks gone
The Boatman
gerritp that would definitely place you on top of my best friend list and also earn you :beerx 24!!!!!
I am in the process of bying a boat so maybe you can join me sometime and show me the ropes first hand!!^^..
gerritp
Sounds lekker.
I have few marks on google earth that i can give you in the mean time, they are mostly for the bay, st Croix, riy banks, quary, 1-3 bos and swg. If i figure out how to export multiple way points on google earth i will mail it to you.
Important. This I learnt from Nico, and will really help you when not sure. Log swell fast wind.. to go or not to go....
Take the swell time and devide it by the swell height.
I.e. A 1,5m swell @ 10 seconds (10/1,5=6.6.) If that number is smaller than 5 then it is going to be a kak day. Obviously everyone will have a different thresh hold and only you can work it out for yourself based on your experiance and confidence. But this is a good rule of thumb. Start at say 7 as your thresh hold and work your way down.
RandomBrad
Hi there apnearules,
Here are some of the weather sites I use to check on launching potential at Noordhoek.  I usually check them all.  When they are all 'singing the same tune', in other words, they all agree - then I'm happy.  When they are all telling me a different story, well, the only way is to get up and go and look outside on that particular morning.
1. Skiboat report - Plett to Cannon
2. South African Weather Service
3. Synoptic chart
4. Windfinder for PE
5. Surfline (check out the sea level pressures here)
6. Pressure & pressure history (don't go out if massive drop in pressure suddenly - cold front coming!)
7. Buoyweather (the most accurate usually)
8. Magic Seaweed
9. Windguru (Seldom accurate!)
The pressure is very important as it'll tell you what the wind is going to do. Look at the synoptic charts & the synoptic predictions on Surfline (sea level pressure charts).  High pressures rotate anti-clockwise & low pressures clockwise.  Pressures of about 1015 and above are 'high', pressures below about 1008 are 'low'.  All the lines around the pressure cells (called isobars) will show you the general wind trend if you picture them to be rotating with the pressure cell.  If the isobars are really close together, there is a large pressure gradient and therefore lots of wind.  If they're far apart, there is likely to be light and variable winds.
Then check the wind charts.  Easterly winds - I stay in bed except for light North easters in winter as these are berg winds and quite nice to fish off of Noordhoek in.  Be careful, NEasters OFTEN turn into Easterlies by 11:00am.  South westers, Westerlies & North westerlies are fine on the wild side up to about 15 knots if there is not a large swell running.  Anything more and the sea turns grey and starts 'shifting' from the west.  Not very nice!
Then check the swell. South easterly swell (predominant in summer) is chunky, lumpy swell 'packets'.  It is caused locally by strong south easters and usually doesn't last long (a brisk west can flatten an east swell in 6-8hours!).  Usually fishing in the east swell is gut wrenching!!  I like to look for a long period west to south west swell - say 11-15 seconds.  The size usually doesn't bother me unless it's low tide and the waves are breaking across the launch gully.  A note from my surfing days near noordhoek:  big west swell = massive west to east current in the launch gully (I have been swept down to the lookout carpark and beyond on more than 1 occasion!!) So be careful if launching through waves in the channel.  Watch your position very carefully if you're moving slowly out, through the waves.  The reef to your left is known as 'Rocky's' and is super shallow with waves that suck dry before imploding!
Another interesting phenomenon is that you can have various different swell directions running simultaneously!  Check out Magic Seaweed and click on an hour that you'd want to go out - say 05:00am sat morning.  It will give you the 'spectral breakdown' of the swell components.  So you could have loads of sites telling you that there is a 3m WSW swell running at 11secs, but you get out to sea and there are these small chops that keep you from running as fast as you normally can..  These are the smaller swell components - see attached image for an example.
Then, there is another massive bonus!! :  Noordhoek skiboat club has got itself a weather station & a video camera that you can log into from your bed!!  R65 per year - what a bonus.  Wake up in the morning, hit refresh on the PC, check out the sea & the wind at Noordhoek and then make the call to go or stay!  Check out http://wildsidedivers.co.za/wildsidedivers/login-form.php
Anyway, hope that helps..  let me know if you have any questions?
RandomBrad.
Didi
I start normally of by reading the wind speed in km/h as knots,it gives you a fair idea of what's the conditions going to be on the water.The swell size don't concern me to much but the period must be long,and I don't like wind.I would rather be on land and wish to be on the water than to be on the water and wish that I am on the land.Thanks for all the good advise
Andre 3000
Hey Brad
Thanks for the links.I live in Addo and its not easy to know what is going on at the coast.
I made use of these links on Friday and caught a 5kg Spotted grunter and a approx. 9kg Kob with the same bait.
:fbash
