Razeen - I've just recently been through this casting story.... here's what I've learnt:
To learn how to "load the rod" -
Get ready to cast. Hold the left elbow as high as you can. Make a "drop" to the sinker of about 1m. Point the rod down to the ground behind you and let the sinker rest on the ground, keeping the line to the rod tip as tight as possible without moving the sinker. Bend your right knee and put your entire weight of your body onto your right leg ie: lean over. Your stance should be slightly open and your head looking up into the sky in front of you. Now, without looking back, smoothly cast your sinker. You must try get in the habit of using your whole body to "get under the rod and push it upwards" on the swing through. Hips and upper body moving like a golfer's swing. This setup and movement will very quickly teach you what "loading the rod" means. Remember it's the rod that casts, not you.
Casting the sinker as a dead weight from behind you will automatically teach you to load the rod. Once you've mastered that set up and technique, you need to do the same thing except with the sinker off the ground. As the sinker moves back in the backswing, you need to move forward in the cast, just as 'Buckled' explains.
Hope this helps
