Gaffing fish on paddle-ski
kentbros
Hi Fellow Paddle-Ski Fisherman
Having recently acquired a paddle ski and taking to fishing off it, my first time fishing on it was somewhat frustrating as gaffing hooked fish proved to be far more difficult that what I had been accustomed to while fishing on ski boats when someone else gafs the fish while you hold the rod. The short of it is that of the 6 snoek I managed to hook, I dropped three of them when trying to gaf them as the line became slack resulting in the hook coming loose. Being so frustrated, I reverted to simply picking up the snoek by the tail.
If anyone can shed any insight or give me a few tips (i.e. where to put ur rod, keeping ur line taught, gaffing techniques) which will allow me more success, it will be much appreciated. I don't think that picking up a crock by the tail will be a similar experience.
Thanks for your help.
Paddle-ski fishing noob.
Danie Burger
Hi Kentbros
I am no expert in the matter, but on the occasion that I did need to use my gaff, I just put my rod in a rodholder and held my leader taught with my hand while gaffing. I must add my leader is around 50 LBS so it's quite strong.
Hope it helps
FAULTY
Howzit Kentbros
Most of us hold the rod in one hand and gaff with the other  . Best bet is to gaff the snoek underneath rather than on top as there is less chance of your gaff touching your line . I have 2 gaffs on the ski as you often have a fish pull it out of your hand and my preferred length gaff is 1200mm . Once the fish is gaffed put the rod back into the rod holder and loosen the drag . I then grab the snoek or couta in the gills and with one swift movement put the fish into the hatch !
Serra Moz
@ Danie Burget, spot on!
@ kentbros, remember to keep your stability/ intact - balance, specially when the adrenaline is pumping trying to land/gaff a BIG one!
I have small floats attached to my gaff and batton, should they fall overboard I will be able to retrieve them
