Gabon 2018
Stefan001
Was reading this thread and thought to myself a lure running on the line would work best when the tarpon is shaking its head while tailwalking. But you guys have covered that now.
Add a ashley Read M special to your arsenal Eugene. It can be fished very slowly and im sure it will produce the goods.
EugeneC
Thanks for the recommendation Stefan, I'll try to lay my hands on a couple, I'm always keen to expand my lure collection ;) The guys fish Sea Iron spoons a lot in Sette, with great results. I couldn't get any before my trip last year, so I bought a bunch off one of the guys in camp, have yet to get them wet though.
Stefan001
Whats the weight of the sea Iron? Have had success with shad on them in Struisbaai, but found they got stuck very often, but we fished very shallow reefs so that was to be expexted. The ashley read spinners are made of tin and can be fished extremely slow. Casting in wind is unfortunatly a problem
EugeneC
The sea iron's I have vary from 1 - 3oz, most of the spots are clean sandy bottoms in Sette, so snagging up is very rare. Only one area we fished where there's supposed to be monster snapper had scattered rocks.
Mikea
Hi Eugene.
I forgot to ask what rod are you using in the estuary.I have always used the trevella 7ft medium but now we will be flying etheopia airlines and they do not allow a 7ft rod case so i need to find a solid two piece and cannot find anything suitable..cheers.mike
EugeneC
Howzit Mike, I use a Black Hole Magic Eyes 754S, which is a two piece. Surprised to hear about Ethiopian airlines restrictions on rod tubes, that doesn’t help.
Mikea
Thanks for that..the airline allows 1.58m
and they calculate that by width +breadth +length and tat must equal 1.58..if you go over that they will allow a max of 2m plus a 50$ fine each way..so even if you take a 10ft two piece you will be charged
EugeneC
Ouch, I guess I’d end up paying ha ha! Are you flying via Addis Ababa? From here I have the joy of flying via Lome, Togo, which if you’ve never done it, is not the most fun you can have traveling. I’d walk if that’s what it took to get to Sette though ;)
Mikea
i fly capetown to tambo to addis and then libreville and stay at Erics house.no more Tropicana rat hole and the same way back.you think the way i do.there is no day that sette doesnt confuse me..what if what if what if....Its now just the river working on me.I make sure i get a few sessions on the river and have done well there..I was into a jack one morning and we where almost against the mangroves when two groups of Chimps attacked each other right above us...imagine that.cheers
EugeneC
Magical place mate, hardly a day goes by that I don’t think of that beach....I’m also pretty amped for the river this time, my last trip the river never came alive and I blanked, looking forward to getting stuck into the little cubera’s between the mangroves.
Mikea
There is a spot in that river that really works.you might remember when you are going to the mouth wellthe first place you see big logs jammed in the shallow .they will be on the righthand side.so about 100/150meters before that bend the river is a bit deep and it does narrow a bit.we fished on a shelf there and the place was crawling with bus snappers and the fish where still there the next day
EugeneC
Inspired by the E Cape yellowtail anglers, I've been giving some thought to braid leaders for tarpon...anyone tried it? I don't like hollow braid, but I've tested bimini-catspaw-bimini / 80lb - 200lb and I reckon it would hold up.
Obvious advantage is easier to drive the hooks home with no stretch. Potential disadvantage is the hooks getting thrown easier on the jump, again because of no stretch...so I'm wondering if the hook set with a braid leader would be that much better than with mono to override the problem of the fish jumping...
Anyone care to drop some wisdom on this thread?
if your mainline is braid, stitch it, then FG to your end mono leader..But watch for hooks pulling with no stretch, the braid hammers a hole where the hook sits vas in the jaw, use a larger but thinner gauge hook then, what is the mouth of the tarpon like?
What about good ol' .55 mono and use it like a bungee? :)
EugeneC
Current set-up is 80lb braid mainline, FG to 1.8mm mono leader, swivel, splitting, lure; nice and simple. The tarpon's mouth is all bone, there's only one small sweet spot where a hook can penetrate relatively easy, the rest is rock hard.
Hence the idea of a braid leader - to drive the hook home harder than I can with mono leader...
Limpopoking
I guess depending on length, there must be very little stretch in 1.8mm mono... What length are you using Eugene?
But the whole argument has puzzled me for a while, when I first started thinking about fishing for tigers... Fish braid for a solid hook set, or fish mono for some stretch when the fish goes airborne. I don't know. I reckon, go with your gut feel but be prepared to change if it's not working.
EugeneC
I use about a meter to 1.5m depending on conditions and it stretches quite a bit actually. I've been thinking about it for a while and probably the thing that puts me off the braid leader idea most is that the tarpon in gabon are most active at night, when it's so dark the fish surprises you with its jumps and dropping the rod tip fast enough is a challenge. I guess if you have no stretch built in dropping the rod tip when the fish jumps becomes even more critical.
Ah got you..ja then braid and braid leader then...on one rig at least and test it, have another rigged up the normal way to swop if it does not work? Practice your stitch though, best way to join braid, full stop.
Fished 80lb braid and 200lb braid leader with 1.2mm leader before, and I'll tell you it is an absolute biiiiatch to cast. Use .55 high abrasion mono and 1.2mm leader now with a grandwave 40 and I loose much less fish and it casts a mile once I've learn't how to. I have the same pulling/stopping power? The stretch helps tire and turn a hard running fish too, while the braid has no forgiveness and I loose at least a quarter of big fish directly due to hooks pulling or wearing a hole where the hook penetrates.. The 10 ft heavy grandwave rig is MUCH easier to cast all day than a 11ft x heavy spinning rig, which feels really uncomfortable to use now when I go back to it haha..I can pull and control big fish easier with the 10ft..One advantage that the x heavy braid has though, with a nice reel with good drag and lockdown, is that you have more power to immediately put the brakes on a big fish about to cut you off, but that comes with the disadvantage of pissing the fish off more and making him more determined to cut you off as well as mentioned with the hooks having more chance of pulling on his direction change. So you can fish harder on the braid but you have to fish easier if that makes sense. Use thinner guage, but larger, hooks as earlier mentioned for better hook holding and hook bend shape is important to not wear a hole, there is a reason the guys use 10/0 - 12/0 kendal rounds on big geelbek with soft mouths, once he is hooked properly on one of those there is little chance of him coming off. To compare, the shape of o'shaunnessy sp? with its bend as opposed to the round curve of the kendal will more likely tear a hole so the hook can come loose. For blue shad the kendal locks and holds too and is less prone to getting thrown when they jump like little tarpons, a circular inline jigging hook in large size also works well and a little tiny treble also holds vas, some more info for you to use or not..
On leaders, 1.8mm is extremely heavy, guys catch huge tunas on the same 1.2mm leaders with long battles and lots of line chaff and they hold up just fine. I've seen it fail with a chaff through only once on a suspected Southern BFT after more than 4 hours of fight..
Also ja, that thick mono has plenty stretch, like a bungee as said.. You must be so amped..what a place to go fish!
