Ah got you..ja then braid and braid leader then...on one rig at least and test it, have another rigged up the normal way to swop if it does not work? Practice your stitch though, best way to join braid, full stop.
Fished 80lb braid and 200lb braid leader with 1.2mm leader before, and I'll tell you it is an absolute biiiiatch to cast. Use .55 high abrasion mono and 1.2mm leader now with a grandwave 40 and I loose much less fish and it casts a mile once I've learn't how to. I have the same pulling/stopping power? The stretch helps tire and turn a hard running fish too, while the braid has no forgiveness and I loose at least a quarter of big fish directly due to hooks pulling or wearing a hole where the hook penetrates.. The 10 ft heavy grandwave rig is MUCH easier to cast all day than a 11ft x heavy spinning rig, which feels really uncomfortable to use now when I go back to it haha..I can pull and control big fish easier with the 10ft..One advantage that the x heavy braid has though, with a nice reel with good drag and lockdown, is that you have more power to immediately put the brakes on a big fish about to cut you off, but that comes with the disadvantage of pissing the fish off more and making him more determined to cut you off as well as mentioned with the hooks having more chance of pulling on his direction change. So you can fish harder on the braid but you have to fish easier if that makes sense. Use thinner guage, but larger, hooks as earlier mentioned for better hook holding and hook bend shape is important to not wear a hole, there is a reason the guys use 10/0 - 12/0 kendal rounds on big geelbek with soft mouths, once he is hooked properly on one of those there is little chance of him coming off. To compare, the shape of o'shaunnessy sp? with its bend as opposed to the round curve of the kendal will more likely tear a hole so the hook can come loose. For blue shad the kendal locks and holds too and is less prone to getting thrown when they jump like little tarpons, a circular inline jigging hook in large size also works well and a little tiny treble also holds vas, some more info for you to use or not..
On leaders, 1.8mm is extremely heavy, guys catch huge tunas on the same 1.2mm leaders with long battles and lots of line chaff and they hold up just fine. I've seen it fail with a chaff through only once on a suspected Southern BFT after more than 4 hours of fight..
Also ja, that thick mono has plenty stretch, like a bungee as said.. You must be so amped..what a place to go fish!
