Flying with jigs
Capiez
Good day
Going on a trip to Madagascar in few weeks.
Are you allowed to take vertical jigs (obviously without the hooks) in your carry on luggage?
Only allowed 20kg check in on SA Express and wouldnt mind taking a few jigs carry on ;)
frank22
no jigs allowed in carry on luggage , no reels with spools removed and no lures with hooks removed.
anything with a semi pointed end not allowed in the Cabin.
who are you flying with???
frank22
oh i see SAexpress , yip mates of mine flew with them when we went to Zanzibar and they had to check everything in cargo hold.
even his fly rods had to be checked
Limpopoking
For what it's worth, LAM have no issue with reels (with spool and braid) in hand luggage... I've boarded about 12 times with them and never been asked. They don't allow jigs in hand luggage. They were also recently fascinated by my usually copious quantities of plastics in my main luggage. Last trip when I boarded in Pemba, they spent a good 10 minutes going through them. I guess they somehow reminded them of condoms and we know what some folk do with those :)
frank22
@limpopoking yeah bud i got stopped in Muscat in Oman by security because they thought i had real crabs in my lure bag ;), when i took them out and he saw they rubber he took one , ran off and called all his mates over to have a look. they thought they where real and could not believe they where made from rubber and hard plastic haha. they had a good chuckle.
EugeneC
It depends a lot on the mood of the staff on the day. In my early travel days I got away with lures and reels in my hand luggage a couple of times, then one day I got stuck, had to repack all my gear and ended up missing a flight as a result. Definitely not worth the risk, rather check in all your gear, most airlines are a lot more strict these days anyway.
Cage
Mada are definitely sticky when it comes to reels or hookless lures in hand luggage. I pack for mada as follows:
20kg check in: Poppers, reels (in a plastic box(big jim type) which goes into my bag for extra protection), terminal tackle, leaders, tools, accessories - towel and a jacket to cushion all the gear
Rod tube: given that they allow 15kg on the tube, I insert a smaller pvc pipe into my rod tube (slightly longer than than my rods) and jam the pvc tube full of jigs... I wrap my rods around this. When you land in Tana - go to the Air Mada counter at international departures to pay for the tube for your connecting flight - it was around $30 for the extra 15kg the last time I flew
Hand luggage: clothing, meds, toiletries, camera, personal items....
Capiez
Cage, thanks for the tips.
Capiez
Capiez
That's so true. Went through the same airport 3 times on a trip in Colombia. Same luggage, same everything. 3rd time they stopped us and we had to take off all our braid of the reels. Almost missed the flight and left a few k of braid on the floor at security.
Serra Moz
Honestly every answer given is 100% correct, although different. I have flown all over the world with Line / Hooks / Lures.
Sometimes they allow you sometimes NOT, (same airline), in Brasil/Africa - they could not care less...300mm to 400mm size (length) vertjigs, no worries, I have picked up hassles from Durban to Jozi (SAA)...
OK, I know what you aiming at, as it's usually an item with weight and now you want to "gain some weight" by putting it on your "carry ons" Hence you can load more stuff in the "checked items" - The problem is sometimes once you checked your stuff, it's difficult for them or a nasty Nazi type lady might refuse to "recall" your checked bag - should they have "red carded" on the carry on idea. What do you do then with the jigs???...Call a friend? So it's a gamble, I also do understand why you want to take your own, simply it's available, and of course cheaper in SA, you pay thru your ass for stuff in Mauritius + Seychelles = Ask me !
So do this, why don't you contact the airline, and explain your story, thus getting a yay or nay, before hand?
Again it's up to the dude sitting at the scanner, but, do wish thathe has a terrible hangover...and overlook you.
