Fluorocarbon Lines
wetstuff
I want to invest in some fluorocarbon line - looking at Berkley Vanish & Siglon.
Both are about R120 for around 200m, other makes are seriously more expensive.
Anybody use these? Comments? Do give them a miss and get the expensive ones?
Hey Wetstuff... I assume you're using it for dropshot? I use Varivas for dropshot and the DoubleX FC for Rock&surf - hectically expensive stuff... R2.50/m! But when it comes to FC, I don't really compromise, since this is the real business end of fishing, and I'll do whatever I can to increase the chances of a hook-up. Also, I don't really worry too much about the price.... 'cos I only use the FC for hook snoots, 1m at a time... so a 50-100m spool lasts a long time.
brettam
Wetstuff, cant agree more with Reefman. Use the best you can, as the only time you are happy when you buy something cheap, is when you buy it.
BigBass
Hi Loams!
If I were you I would not bother with Berkley Vanish, unless they have drastically improved on it over the last couple of years. The Berkley Vanish I tried some years ago was brittle, broke easily and did not hold any knot well - a total waste of time and money!
Other Berkley products are excellent (their Whiplash and Whiplash Pro Baid, for example), but Vanish is not one of them - it should VANISH!
Almost any other fluorocarbon would be better than Berkley Vanish ... Lots of guys in the USA swear by Seaguar as being the gold-standard in fluorocarbons ...
Also as Reefman said, you only need fluoro for the hook trace/ snood.
Please do not spool up your whole reel with fluorocarbon. Apart from being worse for the environment (as it takes ages longer to break down) than even nylon/ mono, it is harder and more "springy" and will not cast as well as mono or braid. If you get a soft so-called fluorocarbon, you can bet its not 100% fluorocarbon, but a mono/ fluoro "hybrid" and will have a nylon "shell" or finish ...
Hey Ziyz... I've bever used it myself, but considering how good the rest of Maxima's products are, it MUST be good. Good old fashioned Maxima is still, in my opinion, one of the best leader materials around. 2c.
Hooked
Its so funny you said that.Was having a chat with a line manafacturer the other day in the UK and he said the following "Maxima is the leader material of choice for tubby , balding middle aged men around the world":D
Hooked
[color=#006600]BigBass[/color] wrote:
Hi Loams!
Easy way to tell them apart is to light the end of the line.If it burns with a flame its not 100% Flourocarbon.
