Flies for my Okavango trip
Pipeman
Hello Guys,
Here is some flies I tied for our Okavango trip. What do you guys think?
Nice Pipeman! Some thoughts from my limited experience:
1) Tie some more sparsely dressed flies because if the water is clear I find them to perform better.
2) On same vein I also really like an all white fly / olive over white with a little flash for during the day, reverting to the darker flies early and late in the day.
Pipeman
I tied some that is more sparsely dressed. Thought I would tie some lighter colours as well. Think I'll also take a scissor with me on the water in case I need to trim down some of the flies.
Any other patters you would suggest?
iana
had similar looking flies that worked well in zambezi..for okavango found that Chartreuse worked very well...
bastion
Hi Pipeman,
Those ones you tied are good colours for the okavango.
Also try some Black over purple (thin strip) over orange. Purple over white is also pretty good.
You can try tapering the back part of these clousers a bit - doesn't have to be neat but the square back part of the fly might put off some fish. If you taper it a bit it might make it look a bit more natural.
A bit off subject, but i noticed you're using swivels - they work well and help for easy changing of flies, but they make casting that tiny bit more dificult. I prefer to use an albright knot to connect the wire to the leader - it's quick and prevents the hinging that the swivel causes. Just something to keep in mind if you're having trouble casting the rigs.
Grant
Pipeman
bastion wrote:
Hi Pipeman,
Grant
Hello Grant,
Thank you for the tips, the flies are actually tapered when wet, they look very realistic in the pool. The guys at fly fishers unlimited suggested I use the small power swivels, so far I don't struggle casting with them can get out my full line
Stones
Hey Pipe,
Nice flies, nothing wrong.
A must would also be a white and silver flash deceiver with a red head.....killer!
Cheers and good luck
Pic is crappy but you get the idea.
Stones
Pipeman wrote:
What flies would you guys suggest for Nembwe and other Bream species?
I would suggest small fry immitations - Baby Doll, white, yellow, red; worm immitations, blood wrom or basically a light brown or olive coulred chanile strand tied over a hook and then your general insect and invertebrate immitations like damsels, dragons and also wooly buggers should work.
Good luck:fswim
bastion
All those that i have caught on fly have been on the same clousers that i use for Tigerfish, although i feel that for the bream the weight of the flies is more important than the weight of flies for tigerfish.
All my good nembwe have been caught tight to the side (clay or reeds) and deep so the flies must hit the water and get down before the current pulls them away from the side. I have had most success with darker coloured heavy clousers like black over orange or plain black with a bit of red flash (Got 2 8lb Nembwe with this fly on my last trip to Zambezi). Bang them into the bank, let it sink, and then strip. If he's there he will eat it on the first pull 9 times out of 10. Aim for little depressions in the reeds or clay banks - they like those.
