Garcie wrote:
Hi Guys
I would like to know from other Sealine members, what would be the ideal rod tip and sinker weight to get maximum distance when casting using any reel type.
Garcie,in your avatar seccie,you have set up I once used :- L&F shockwave(Mine was 14ft/5-7oz) and Grandwave 30.So,I assume your question is related to this set up?
Great set up,I still miss that rod,but dropped medium tip on rocks,which was my main weapon for casting,and sold rod.I'd love to get another Sh/wave,but think blank may have changed!
My Sh/Wave coupled with that G/Wave worked best for me by using medium tip with 5oz sinker,and .40mm Kingfisher line.Heavier sinker shortened my distance somewhat.But it's not as simple as just getting tip & weight right to improve distance.
What you also need to consider to maximise cast,and use of that reel,as it's shaftless,is to pull out bearings,that run on spool, after every +/- 5 or 6 times ,and lubricate them.
Get to know your reel,and how to lube it,it's very simple,very rewarding,and you'll get better distance in casts.Takes like 3 or 4 minutes once you get 'reel friendly'.
I don't believe in greased bearings running off spool,as it slows bearings down,but each to their own if they use grease.
I recommend you remove any signs of grease on bearings that run off spool for improved casting.I use 2 or 3 drops of Prolong on each bearing.
Then the cast - I know you're not asking about cast itself,but you can try to incorporate a half pendulum cast from the front,instead of just behind you,in order to double load the blank,and gain some distance in cast.
I took Morbus to strandfontein yesterday,and showed him the gist of it,although it takes months to perfect.
I'm right handed,but throw unorthodox,with weaker left hand,and instead of changing to orthodox,I rather incorporated this half pendulum type cast which has improved my distance somewhat.
The Bait - Cotton it up well and clip it on Grapnel to keep resistance to a minimum in the cast.
The Rod - Hold it right at end where handle meets blank area,and you'll have more control of rod.
just my 2c!
