Far distance casting
Garcie
Hi Guys
I would like to know from other Sealine members, what would be the ideal rod tip and sinker weight to get maximum distance when casting using any reel type.
Marthin
Garcie there is more to this. Line diametre plays a very large role, some reels take a heavier sinker to get up to speed...
Marthin
Speedmaster, 7ounce small bait or 6ounce kob bait, .45, bm g3 6ounce tip, the old t24 blank.
Speedmaster, poseidon xxheavy 9ounce tip, .50, 10ounce slide sinker or 8ounce and throwbait.
Gw40, .40, 5ounce, heavy tip bm G3 new green bm rod.
Garcie
Is it true the heavier the rod tip(less flexibility) , 7oz sinker and lighter line, the further the cast.
Elf 786
hi garcie
like marthin mentioned , line diam plays a big role. when i started fishing i used .5m and have thus dropped to .4 and can see a huge difference albeit my max cast is probably only 80m lol.
anothe mistake i made was to overspool my reel. less line = more distance. Also when a rod says 3-6 Oz it means max 6Oz with ur heavy tip! i've seen alot of guys using there med tip.
i use to use 60z when using maybe a chokka and sard combo for kob which ends up being a 70Z ( bait plus sinker) i then went to 5Oz and this gives a nice balance. when using smaller baits eg prawn and worm i use 60z.
Garcie
The reason I brought this topic up is that I am fishing over 15 years now. On a calm day, medium tip, 6 oz sinker is perfect for maximum distance which is how I fish. Windy condition seem to upset this setup. A fellow angler over the weekend outcasted me with his heavier tip. So can we say that weather conditions play a major role when choosing a tip and sinker.
Marthin
What line diametre are u using.
With wind, 1st is ur line diametre. Then with this in mind, was he clipping his bait? If both were or were not...
Then sinker weight. If the wind is blowing, the heavier sinker will go further. But if u are balanced with the 6 ounce, it won't always be with the 7 ounce... As elf said.
Then casting style comes into it as well. A nice smooth action might work on a windless day, where in wind a mik en bliksem action might work better. Trajectory, using the wind(if it's coming from slighly behind but more left for example, walk to your left a bit and cast skew but use the wind).
kopstamp
Casting into wind is difficult as you have cleary seen.
As marthin also staTED casting a harder shot into the wind is normally needed. On the other hand I feel, that like with golf if you hit it right the wind has very little effect. But the distance with a headon wind is always noted.
What diam. line are you fishing?
Garcie
I did notice that this guy casted at a slight angle(skew) with the wind. Thanks guys for your input. I will be casting futher  in the wind now that I have all my facts together.::S
Walt
Garcie wrote:
Hi Guys
Garcie,in your avatar seccie,you have set up I once used :- L&F shockwave(Mine was 14ft/5-7oz) and Grandwave 30.So,I assume your question is related to this set up?
Great set up,I still miss that rod,but dropped medium tip on rocks,which was my main weapon for casting,and sold rod.I'd love to get another Sh/wave,but think blank may have changed!
My Sh/Wave coupled with that G/Wave worked best for me by using medium tip with 5oz sinker,and .40mm Kingfisher line.Heavier sinker shortened my distance somewhat.But it's not as simple as just getting tip & weight right to improve distance.
What you also need to consider to maximise cast,and use of that reel,as it's shaftless,is to pull out bearings,that run on spool, after every +/- 5 or 6 times ,and lubricate them.
Get to know your reel,and how to lube it,it's very simple,very rewarding,and you'll get better distance in casts.Takes like 3 or 4 minutes once you get 'reel friendly'.
I don't believe in greased bearings running off spool,as it slows bearings down,but each to their own if they use grease.
I recommend you remove any signs of grease on bearings that run off spool for improved casting.I use 2 or 3 drops of Prolong on each bearing.
Then the cast - I know you're not asking about cast itself,but you can try to incorporate a half pendulum cast from the front,instead of just behind you,in order to double load the blank,and gain some distance in cast.
I took Morbus to strandfontein yesterday,and showed him the gist of it,although it takes months to perfect.
I'm right handed,but throw unorthodox,with weaker left hand,and instead of changing to orthodox,I rather incorporated this half pendulum type cast which has improved my distance somewhat.
The Bait  -  Cotton it up well and clip it on Grapnel to keep resistance to a minimum in the cast.
The Rod - Hold it right at end where handle meets blank area,and you'll have more control of rod.
just my 2c!
Fluffy
3 piece cast farther. get stroke 6 with nice 6 ounce weight and 0.45 line on a tor30/saltist50/sl50sh/
Bigger reels have bigger circumference of line coming off with each spin.IMO throws further if you know how to handle your reel.....
hjdj
Guys,
What is your opinion on using a shockleader in all this. I've started using a shock leader(because they say you can put much more power on the cast this way(using pendulum or beach cast) without concerns of your sinker breaking off your setup and flying along the beach). However, I have found that the knot connecting the leader to your main line only lasts for about 6 to ten casts, then it is worn out(because it hits the rod tip ring with most casts) and breaks off either while casting or when your sinker is stuck.
Opinions?
DieterW
hjdj wrote:
Guys,
Opinions?
Use a wind on or increase the size of the eyes.
Your knot should last way longer than 6 casts.
