East Coast AM Report....
Kenty
Good day Folks , we moving onto a dark moon spring and the two systems that have been idling towards our coast have finally made landfall and the west is on us at over 50kph gusts as I do this report...
Lovely early morning low tides sees you with a low at 08h02 tomorrow morning and at 09h10 on Sunday morning...the swell is running long an big offshore at around 10f and at an even 5 to 6 ft inshore in a south westerly direction ..I am not to sure about any surging , but one must always be wary during an approaching spring tides...
The tidal variance over a 12 hour period will be at 1,2m mark...
IF , the systems keep track , and the high ridging in behind the fronts , which will change things early Sunday AM , then your window might be very small this weekend ...
from late arvie on Saturday through to early Sunday AM...if you a night time fisherman , then you in for some calm...
It is going to be a very tight timing weekend this weekend and for one will be watching the barometer extremely closely...
Keep the Faith and stay SOLID out there...
Kenty
Good day Folks , well , its going to be an iffy weekend along our east coast this weekend , and NOT to say you will not get a fish , but , its going to be hard work...
With that VERY slow moving high ridging in , its going to be a beastly eastly all weekend and tomorrow it will puff properly...
That being said , a window will open on Sunday arvie and i think that will be your best option and with a low tide at 14h29 on Sunday , it wouldnt harm to fish on the push...
Spots to look out for would be Glen Gariff beach area as that water temp drops and a piggie may just have your name on it , IF the sea is not up ...nice east choppy water and coldish and you will be in business...
Another piggie playground is left of Cefane towards Bosbok ...could be worth the walk ...
You have a high tide at 07h32 tomorrow and at 08h23 on Sunday ...the swell wil switch from SSwest to a more direct southerly directio as that east gets up to speed...the temp is at around 20 and will certainly drop in the next 24 hours ...
Tidal coefficiency will be at an even 0.5m over a 12 hour tidal period , so , hoepfully no surging is expected...
Modify message
Kenty
Good day Folks , this weekend is lining up for a pretty decent fishing weekend...as you look at the synoptic , you can see the coastal low busy passing and the barometer has bottomed out and as that high starts ridging in the glass will start to rise and the wind factor will be almost a non event for both Sat and Sun mornings coupled with an approaching bright moon spring and early AM low tides...
Saturday sees you with a low tide at 08h29 and on Sunday at 09h06...
The water temp is sitting at an even 20 degrees inshore with a 2 to 4 foot swell running inshore and 5 to 7 foot off shore in a South south west direction...there is no surge expected or predicted and the coefficient variance is between 0.5 and 1.5m over a 12 hour period...
BUT...seeing as its leading up to bright moon spring , which is on Monday , still watch as that tide turns on the low and starts to push....
The water is gin clear in most spots along the coast and fresh bait is a MUST...
Poensie and silvers may well be out n about , so be prepared...
Keep the Faith and stay SOLID....
Kenty
Good afternoon Folks , DAMN these systems are soooo predictable at the moment and we once again lining up for a SOLID fishing weekend here on our East coast....
As you look at the synoptic , you can see at 12h00 today that smallish front just off of CT and that high hanging over our coast ...we are coming off of a cold front and the west has tapped off dramatically and the swell has picked up somewhat as that front slipped off to the south...
The barometer will be on the rise by this evening later and tomorrow morning will be a good window as well as Sunday...
Saturday sees you with a high tide at 06h14 and on Sunday at 06h48....
there will be a eastly swell running and the outgoing tide might be a tad slow...spots to look out for would be Cefane beach area as that tide runs out and Glengariff is a good option for the out and the push...
Swell might be a bit up for Haga and surrounds...
as that baro rises the wind will switch to light east on Saturday and then a tad stronger on Sunday ...
We coming off of a bright moon spring so the tidal diffrence in height will be about 0.6m to 1.2m
Modify message
Kenty
Good day Folks , trust your Friday is sailing along...
Everything on paper certainly looks the part as far as conditions go for actually hooking and landing fish this weekend...the water colour , temperature and even the weather systems are lining up very favourably ...BUT...as we all know ...will the fish be at OUR spot ...THAT is the million dollar question....
As it stands on our East coat , the sea is a bit up and with a 10 to 14 foot swell running off shore that only brings a surge and a inshore washing machine ...
That being said , as Saturday approaches the swell should tap off quite a bit , especially towards Sunday in the AM...
Saturday finds you with a low tide at 07n12 and on Sunday at 08h15 , both early morning low tides and this bodes well for those looking for shad on the various points along our coast...
The water temp is around the 18 mark and super super clean , as we approach a dark moon spring , there is already a surge on the sea , so p-lease be aware of that when the tide turns on the dead low...
Well Folks , as these conditions play out the fish should be there....
Keep the Faith and stay SOLID out there....
Kenty
Afternoon folks , we are moving towards a bright moon spring and this weekend its almost another neap tide weekend , with a high tide at 06h23 on Saturday and at 07h00 on Sunday ....as you look at the synoptics the wind will be pretty light this whole weekend along our coast ....
Its a light west from Sat AM through to Sunday around 17h00 when the west will come through quite stiff as those coastal lows make landfall...
the water is still clear and temp around the 18 mark...
Keep a look out for any surge as the inshore swell is running at between 3 to 6 foot...
Keep the faith and stay SOLID!!!
