Yip works like a charm, even works in winter but you must find loose damp soil and they will come out in the dozens , and you must use atleast 3lt before you get any results, warm water also helps
Ja werk soos 'n bom. Soos genoem gebruik warm water en lekker baie van dit. Spoel net die outjies af met skoon water na jy hulle gevang het want hulle laaik nie daai sunlight water op hulle nie.
Sounds cruel!! And do the earthworms really work after been soaked with sunlight, i know that if i was a fish i would steer very clear of soap flavoured worms!
just out of interest, did you guys know that sunlight liquid is one of the only washing liquids that work with cold salt water, i used to be cook, dishboy and diver a good few years back on the west coast diamond boats
A strong Mustard solution (Hot English Mustard) in warm water achieves the same result, is kinder to the environment and you don't have to rinse off the worms ...
If you have space, get an old bath tub and plug us all the holes. Then fill it half way with compost/soil mix, cover with banana leaves and put in a few worms. every so often put in some veg waste under the leaves. Apparently they grow big and fat and mulitply as well...
Then there's my personal favorite C4 and some serious det-cordonly issue is the cops harrasing you while picking the worms up and off structure around your house......
