Dropshotting a Surfzone
Predator_828
Today I went off to Maitlands for some first time Surf Dropshotting. I took my 5ft river spinning rod with since I don't have any other spinning rods (2500 crossfire with 15lb braid).
Using a 1o'z sinker and one hell of a throw I was able to cast about 20 - 30 meters. But I just found in general that my tackle was not really suitable for the job. Well now to my actual question.
What tackle would you guys reccomend for the surf for general all round use? Rod, Reel, Braid, What weight leadheads and if some of you could even reccomend some baits and techniques.
Here's the equipment which I figured would work nicely. Please correct me if this stuff is unsuitable.
• 8ft rod (With a stiff taper and rigid structure) I am looking for a light rod that is as thin as possible.
• Daiwa Regal or Crossfire 3000x
• 25lb Suffix braid
My second question is what should one look for when targeting Kob and Leeries?
Thanks in advance for any help.
caesar
The problem I found was to find a long enough rod to get the distance. I then decided to use my 12 foot Loomis graphied carp rod. With it I use a Slade 4000 with 15 lb line and 30 lb leader. It works like a bom. I did try braid but find that it tangels alot. Maybe I do something wrong but I took it off and only fish with nylon. With a 2 ounce drop shot I get about 100 m. Many have looked at me funny when they see that I use a carp rod, but it works.
Bending Rod
Hey Predator_828.
Use google and type in Eastern Cape Lure Angling Club. On their home page is a tab - Getting Started. This should give you a good idea of what you will be needing. Hope this helps.
predator 828
like i said in the previous post before i pressed the send button.I just recently bought the combo set for surf spinning and the rod is _+ 9ft long.I had been using should i say compromising with other spinning gear old school and nylon and watched many a session where guys came along with the rightous gear and caught and i struggled to get the distance and correct action.This coming summer will be my first season with my new toys and can`t wait to hook into a leery and cob.Been trying this winter but no luck thus far as the surf on our beach has been a bit onderstebo.Another good point is i did`nt have to break the bank as they say and bought decent gear at affordaable prices.my 2c worth<used it or abuse it>
Jakes101
Hey Predator. Like Bending Rod said, go have a look at http://www.eclfc.webs.com/. Moose did a nice article (Introduction to surf spinning)that will give you lots of info.
Heatseeker
Must agree, have been using my L & F 12 foot carprod, with .15mm braid and a 2 ounce clone or 2ounce leadhead, works beautifully!!!!
One way of utilising my dusted carp gear, have had some funny facial expressions from some of the gesoute manne though......
