Daiwa Monster Mesh------ Has anyone had any exp
Has anyone had any experience with these Jigging rods? Rated 12kg Drag, 200g lures, butt join... felt one the other day, awesome power for R1600...
Hoodlum
Hey Reefer... I just got one yesterday! feels gr8...and dying to test it!
Anyone else have the opportunity to put it through its paces...!?
Nepptune
Heard good things about them Reefs... but I've never handled one so can't comment on them... But they seem to have a good following and some impressive catches...
200G is a fairly light  Jigging stick... and with a max drag rating of 12 kilos meaning you'd be fishing 8 to 10 kilo max....
Perfect PE 4 to 6 rod, and fishing PE at a push, but I would stick wth PE 6 max... Perfect for most of our conditions here, and would be an awesome Yellowtail,Sankora and general jigging with 100 to 250 gram jigs at a push....
What length are the ones you seeing?
Hoodlum
Hi Nepps
I got the 8.3f PE 6-8 heavy...  Only this is it detaches at the but section so that leaves you with a 6f piece of rod and it comes with a rod cover...so you need to get your own tube. So it will not be the easiest to travel with....
Other than that...it feels good...just need to test it now!:spite
Nepptune
Hoods - Thats the popping stick then, DEFINTELY not the jigging stick... waaaay too long for jigging... Sounds like a great stick though, hope it sees plenty of big GT action in your hands buddy!
Just get some PVC piping and make up your own rod tube...
I fit about 6 rods in mine, and its only about 6 inches in diametre....
K.... here we go.... just couldn't resist. Actually... couldn't say no... they mad me an offer I couldn't understand! LOL.
DAIWA MONSTER MESH... 5'8"   - PE 6-8 -  200g-400g    -  Max drag 15kg
For... R1250! A steal...
royboy
Reefer - that is a GOOD looking rod! Are you going to use your Stella on it with 80lb?
Very very nice. Agreed, you got it for a steal!
Why do I see a Daiwa Monster Mesh Vs Shimano Jigwrex discussion brewing here? Wooden spoon mode.........
Carlos Moran
Those Jigwrex rods are the bomb,Wesley Rapson fished with one for Tarpon,coupled with a Stella 20k,pulled the fish faster than with 50lbs standup gear and tiagras.Sweet looking aswell.Have any of you had problems with speedmaster sticks?
RB... I'm probably going to try my Saltist 50/Grandwave 50 with Braid on that Rod... I've recently seen a trend of guys converting back to the Overhead method, just for ease of use and for the increased line capacity?? Dunno... I'm still not sure though... weighing things up.... If I had the budget, obviously I'd buy another Stella for popping as well, but I've got all these good multipliers, might as well use them...
Or maybe I should use the Stella on this Rod for jigging, and then use my Saltist with Nylon on the Exage popping rod... These JEEP okes have confused me big time now... have you seen that most of them pop with NYLON...!
royboy
Hey RM, trust you are well mate!
That has been my preference with my TRQ300 on the Beastmaster jigging rod. I have loaded it up with Ande PE8 so now another month before it gets wet.. A LOT of guys are doing that - overhead on jigging, and spinning reel for popping.
Yes, I saw that on last nights episode. It does make sense though - think about it, you are retrieving a big popper fast towards the boat and a BEEEEEEEEG GT smashes it!!! It will normally be a visible take! Lucky not to have the rod ripped out of your hands due to some stretch in the nylon. Braid would be more tricky as there is no stretch........(so my logic says anyway - which is why on the Spheros I have around 50M nylon on top of the 50lb PowerPro - a bit more forgiving).
Jigging is the opposite, you need good contact with the jig to set the assist hook on the take, and you need to winch the fish up vertically which is why the jigging rod is a lot shorter, has a softer tip, but much stronger butt section.
Go and have a look on 360Deg Tuna (dedicated to jigging & Popping): www.360tuna.com
Register on the site and go to their forums, there are guys there who use the Saltist for jigging and swear by it!!!! Sounds like a good match.
Thanks Roy... will check that forum out too... flip you and Nepps are everywhere! Can't seem to get away from you guys... hehehehe
Hoodlum
lol...Reefman I see Abdullah twisted your Rubber arm or was it Hasain..hee hee
Congrats on the new additon mate....now you need to break it in join us in mozambique in November! You still have to try my Mutton Potjie bru!
Neps...bud yes you are right..i will be using the Monster for popping and the T-Curve for jigging....got all the goods now just need to get to the ocean! *grin*
Nepptune
Very nice Reefer, looks like a great set up mate.... And at a great price! Congrats!
Reefs - I wouldn't sick a overhead on that Monster Mesh.... It would be wasted.... that rod is designed and built around a spinning reel set up... the guides will be wrongly placed for an overhead, and you'll get blank slap or worse on a fish....
Put the spinning reel on there, and stick an overhead on your Exage is you must, but you are more likely to fish HEAVY drags on the Jig set up, and if you stick an overhead on there, you risk breakage, as well as you rob yourself the experience of a truly magical set up, fishing with is as it was designed...
Overhead jigging set ups are still very much a personal preference, and almost a trend in some areas.... NZ guys are almost all overheads... Taiwan - overheads, Japan - Spinners... US East Coast - Spinners, US West Coat - Overheads...etc etc... Of course there is always guys who go against the grain, but so be it....
RB - You'll see guys like Kilsong and such from 360 and deepjigging often use long 7 to 8ft rods and regular overheads like Toriums/Saltists etc to target tuna on gigs... this is when they are fishing off big boats, and using diamond jigs and yo-yo jigging rather than mechanical jigging.... they also then fight the fish "crossways" with the handle under the right arm, AND reeling with the right hand....
I'm all kitted out right now with 3 Stellas ( 6k, 8k and 20k ) and Light jigging, heavy jigging and heavy popping, but my next set up may just be an overhead light jigging set up... something along the lines of a Jigging Master Powerspell 150 or 200, matched to Accurate 197 with PE 3 or 4 ... perfect inshore set up, and fun as hell.... But I gotta start saving first.... :)
Lekker to have some more guys participating in this section of the site, stoked to see.
Thanks bro... yep I'm stoked with the rod... tested it with my son hanging on the tip... gobsmacked at technology of these blanks... unbelievable power!
Moz in November... no such luck... there is an outside chance I'm gonna hit Kilwa though!
Mutton Potijie... eish bud, you're gonna have to bring it to one of our socials at Leeuwkop, bung it in a Bunny... hmmm - we got some serious Bunny connoiseurs in our GP gang...!
Thanks boet.
Whats Blank slap!?
I actually put my Saltist on it on the weekend and messed around with it... the guides are kewl... being such a short rod, it doesn't really make a diffs when a Spinning reels on or a Multiplier... the first guide is quite close to the reel and the line goes perfectly thro the middle with both reels...
Look, I know that the Stella has much better drag etc... but I see many of the SA okes, including the Jeep guys, Paul Borcherds, Mark de la Hey prefer multipliers on the Jig??
Nepps, another thing... is the Exage decent to cast with when compared to the better rods...?
Hoodlum
We on...will look out for the next GP social.
When you guys thinking of for Kilwa....been toying with that idea for a while.
Gonna have to upgrade to stella 20000 then....lol
Carlos Moran
I prefer the overhand reels on the heavy stuff,After using the spinning reel for a while,my left bicep burns like fire.on the lighter stuff spinning is the way to go,my 1 zuma rand
